Water Ingress and pooling in body cavity
bakepl
7:21 PM
Brisbane, Australia
Whilst installing electric steps, pulled out rubber plugs of the passenger side of the body (RHD) and water poured out. Drivers side was dry. Vehicle has not traversed water crossings - only rain/washing. In the image is a step bolt I've placed in the hole as it helped to wick out the water. Any ideas where this might be entering the body? If I hadn't been installing the steps would have been none the wiser. Call to dealer I suspect.
Most likely water has been pooling between the door seals and then going into the sills via the threshold capping. Have a slow look at the outer door seal on the wet side; it is probably not glued down properly.
It should be a easy dealer fix - providing they can get a replacement seal if the original is stretched.
See also - https://www.theineosforum.com/threads/door-seal-delamination-repair.12415587/
That water came from the INSIDE of your vehicle.
I found that out after I removed the interior drain plugs and hosed out the inside. I heard water sloshing around for a few days unable to find where until I found these.
You can have water in the sills and in the floor. If you drive with the rubber flooring out and brake, if it is in the floor you can see it flowing for and aft as you accelerate and brake. If you have the rubber flooring out, can hear water and cannot see water sloshing, it's in the sills.
(Been there, done that).
Did you figure out how to drain the water in the sills? I have the same right now after cleaning mine with water and using the drain.
I have the same issue the water must have come from above either the safari windows or the roof handles - mine was on both sides and about 2 litres a side - I have contacted dealer but seems unlikely Ineos will address
Yes, not an unknown issue thats for sure. I don't have the safari windows if this is any help. Sent photos to dealer showing water pouring out.
Open the bonnet and check out the seal between the firewall and the plastic duct(?)
I’m pretty sure this is an ingress point for what u talking about.
Mine is right hand drive.
Look just below the left bonnet hinge and badge as in picture
Is there a good solution to this ingress point? I think this is the source of the water in my LHD driver’s footwell.
The water is coming in under all the mats probably from behind the A pillar. The mats and door sill are all dry. I’ve taken to leaving the plugs out of the footwell and out from under the frame rails too. At least the water drains out instead of just sloshing around in the frame or footwell.
I haven’t contacted the dealer about this yet.
I’m waiting for a replacement battery and when it finally arrives they can address this, the toot horn not working, and the leaks.
I imagine that this panel could be removed and re sealed with silaflex or similar.
There is also a service action for water ingress into the rear cross member. To address this, they access two bungs under the starter and aux batteries and put some for of sealant in there to prevent further ingress. Check with your dealer if your vehicle requires this service action.
