Turning Radius
The turns lock to lock I read as 3.85. I think my ford is something like 3.
I wonder if the choice to have that level of increased input precision presented the issue of the chosen off the shelf box running out of manufacturer recommended movement range, necessitating a premature stop of the steering angle. Which would have made it an engineering compromise for what the designer prioritized, not a design flaw. Anyone have a solid working knowlege of recirc ball design, that they could make an informed opinion on that? I don't see how that would affect a rack and pinion, but the ball box may be different.
Recirculating power steering design. This will be near identical to the Grenadier steer system except for the vane pump being an electrohydraulic gear pump.
Well... if one increases the turns by making a change to the input via making a finer "thread" on "ball rack/shaft" assembly requiring more turns to move the rack, I don't see an issue. BUT if one were to increase the needed turns of the wheel to move the drag link "x" distance by adjusting on the output side, by merely making the pitman shorter, the rack would run out of usable travel. Minor corrections would also need much more input causing wandering sensation.
At least that what I see. correct me if I'm i'm in error.
The diagram is the larger version of the ZF Bosch steering box manual for 5t truck. The Bosch unit in the Grenadier is a hefty unit and will follow similar a design with size and the mounting orientation and case position being the only real difference.
Likely to put excessive loads and shortening the service life of the torsion bar that is connected to the steering wheel when the piston is forced on the stops too often.
I do not believe the issue is the steering box limits. When you max out a steering box they hard stop internally. You cannot keep turning it, the torsion bar won't allow any additional rotation either.
A slightly longer pitman arm would both reduce slop and increase steering angle as well as reduce lock to lock rotation. I have seriously considered altering mine for some time, but my truck seems tolerable now with the stops opened up a bit. It easily reaches full stop as long as I am moving.
I think the primary killer is the programed stop of the pump based on steering wheel rotations. I truly believe the pump stops delivering pressure at the software stops. The mechanical stops on the axle are just to mechanically protect the drivetrain on minor impacts.
I’m a late-comer to the party having only just seen the YouTube video on the topic. However, as I have to park my vehicle in some fairly small carparks for work, I decided to adjust the steering bump stops on my vehicle to see if it might tighten up the turning circle.
I have the non-adjustable Fox Steering Stabiliser fitted to my RHD Australian-spec Grenadier.
The first thing I would say is that even before I performed the mod, the bump-stops on my vehicle were absolutely pristine, with no evidence of contact with the corresponding flat area/stop on the axle casting. So despite performing many full-lock turns in both directions over the last 18 months, I had obviously never actually engaged the bump-stops. I suspected that there would be no appreciable improvement to the turning circle by burying the bump-stops even deeper into the front knuckle.
I didn’t go down the 2-washer path and decided just to screw the nut down tight on the bolt and tighten the bolt again.
After driving the car for a day or so, there really hasn’t been any significant change to the turning circle on my vehicle, despite performing several deliberately tight turns in both directions and the bump-stops still look pristine.
I think there are other aspects of the steering geometry that govern the turning circle on our beloved Grenadiers that are not able to be overcome by this simple mod.
I went with two 7/16 heavy duty washers this week (9 months after John with Agile posted the AO video “just in case”) and find the outcome well worth the effort.
I would say it improves the overall radius by about 6’ / 2M and has eliminated three point turns getting into parking spaces in the places I roam. The steering stop bolts have 19mm heads and unlike the Agile Offroad video required rattling them off with an impact driver.
I like to go for that. What is 7/16 in metric dimensions? Seems there are 2 standards in the US, USS and SAE:
And they are different in thickness. The M12 washer (DIN EN ISO 7089) here in Europe has a thickness of 2.5 mm, which is thicker than the US washers. How this will effect the turning circle?
I'm currently rebuiding a Saginaw recirculating ball steering box. Research suggested that pushing these boxes to the maximum sector shaft angle at either end of their swing - even on the bench - can result in internal damage. I know the one used by Ineos is from a different manufacturer but the same caveat may apply.
And these considerations seem to confirm my concerns. I wonder, however, whether in a world so vigilant about every form of complaint and compensation claim, IA would have left that (very accessible) option open if it actually caused harm. It would be difficult to declare the driver's behavior inappropriate, as it merely involves exerting a slight additional effort on the steering wheel...
I don't know how it would be judged in the United States, but I'm sure that if I were to have a serious accident in Europe with a Grenadier with modified steering components, I would have a difficult time, both in terms of personal liability and with regards to insurance...
The washers used in the AO video are what are called “heavy duty” which in the US mean that they are thicker than standard washers. I will get out to my workshop and measure them later this morning.
So my measurements are as follows:
The original steering lock nut is 6.9 mm thick as measured partially painted and has a ID of 10.3 mm measured at the threads.
The washers I used are described as: SAE Extra Thick Flat Washers Z8 7/16” and measure 3.08 mm thick and 6.2 mm when stacked together, so slightly less than the OEM nut. My washers have an ID of 12mm and fit well over what I presume was the 11 mm steering stop bolts.
I purposely am not an early adapter for these kinds of modifications. I think for obvious reasons, but mostly it’s because I don’t have the kind of money most of you have and I don’t want to spend $$$$$ on a modification that would be deemed to have voided my warranty.
That said this mod was done on my old guy back in <30 minutes using a 1/2” electric impact, 19mm socket and an extension. You could do it with a wrench, but I would recommend doing that up in the air or at least with the wheels and tires off. The Agile Offroad video made it look pretty easy and it was but it wasn’t that easy. You’re not going to just walk up and turn the lock nut with an open and wrench at least I wasn’t going to be able to do that.
I have read opinions that say that the OEM stabilizer is hanging the front end of this vehicle up with respect to turning radius. I don’t know about that. I didn’t leave my OEM stabilizer on long enough to form an opinion one way or the other.
I will tell you that with the adjustable Fox ATS stabilizer set at 12 which allows / requires a certain amount of driver input to fully self center and the tightening up of the steering stop nuts or replacement of the nuts with 6 mm of washers or spacers my Trialmaster’s steering is rugged yet civilized.
Did mine last night, by hand with 3/8” ratchet and 19mm socket - two 7/16” washers per side, done in 7 minutes…
I just remove the jam nut and screw the stop bolt in until it stops from the bolt shoulder touching threads.
With truck on the lift you can cycle the steering by hand on the axle until it hits both stops. The wheels turn with zero bind at full lock.
From this page: https://www.huyett.com/all-products/washers/flat-washers/uss-flat-washers
_________________________________
USS Flat Washers​
USS flat washers are named after the United States Standard and were initially produced for use by the US Navy. These washers are generally larger and thicker than SAE washers, which makes them ideal for applications requiring more load distribution. Their design is particularly beneficial in industrial environments where larger fasteners are commonplace, ensuring a reliable and sturdy assembly.
USS flat washers’ oversized design helps in distributing the load more evenly, which is crucial in protecting the surface of the material being fastened. This even distribution of force also helps prevent damage and wear of both the washer and the assembly. In scenarios involving large fasteners or bolts subject to significant stress, USS flat washers are the preferred choice due to their enhanced size and related characteristics.
  • Enhanced Load Distribution: The larger size evenly distributes the force over a larger area to protect surfaces and prevent material damage.
  • Vibration Resistance: They are ideal for applications that are exposed to vibration.
  • Secure Grip: USS flat washers prevent loosening of fasteners, which is crucial in high-stress environments.
Difference Between USS Flat Washers from SAE Washers in Size and Application​
USS flat washers are larger in both outer diameter and thickness compared to SAE washers and also feature a slightly larger inside diameter. This larger size makes them more suitable for industrial applications involving larger fasteners, where a more secure grip and load distribution are required.
Are USS Flat Washers and SAE Washers Available in Through-Hardened Steel?​
Yes, they are. While SAE and USS flat washers are most commonly low-carbon steel with plain, zinc-plated, or hot-dipped galvanized finishes, both types are also available in through-hardened carbon steel. Through-hardened carbon steel washers can be used in structural applications, paired with SAE J429 Grade 5 & Grade 8 bolts and ASTM A325 & A490 structural bolts. These hardened washers must be stamped with a manufacturer's mark or grade marking for visual identification.
I believe the "thick" versions are usually hardened. hth
Why the need for washers?
I think it's supposed to be an easier way to adjust in the stops equally on both sides rather than fiddle with the jam nuts. I think they say it only works with aftermarket stabilizers.
It would be just as easy to back the jam nuts off the same number of turns on each side and then turn in the bolts. A final torque of the jam nuts and you're done.
Completely removing the bolt from the knuckle and fitting washers does give you the chance to add some copper grease so there is that benefit .
