Turbo Oil Leak B57!
What was your outcome Tom?
Fixed under warranty, I read online that some BMW's had the same issue, Looking at the hose it leaks from where the rubber section meets the steel pipe, it's hydraulically crimped on, either there's insufficient crimp pressure or too much and its cracking the steel. I noticed the replacement part had slightly different rubber hose. I guess they have rectified it.
Putting this out there since it sounds like it's not a Ineos design/part mistake but BMW engine issue. I will add on my B58, I had a hose that was leaking coolant. 2400km on the clock. I wonder if BMW has a hose supplier issue.
