Triple R / LAZER Sentinel Grill Lights
Good question. I bought them but on reflection I don't think they will fit in the housing. I might send them back. Will let you know once have a definite answer.
Fingers crossed, hoping they will fit. It would be a nice addition. Looking forward to what you find.
Found another option if the covers dont fit. I forgot I had some clear yellow vinyl laying around.
Happy with the result. Not sure when will get to test them in the dark, might pop out just before bed!
Thanks to @Tom D for answering some fitting questions which helped a lot as the instructions from Lazer lacked some details.
Just installed my Lazers behind a bull bar. Had to remove the bar for installation, which was pretty easy.
Wired them up using the factory driving/aux lights power through a relay. This allows me to use the ceiling panel switch to activate/deactivate the Lazers to come on with my high beam.
Nice…hoping to have mine done by now or early next week. My QM is a Guinea pig for the 4WD shop so I’ll inform them about the overhead switch option you have. Thanks.
Can you share some details or a photo how you have wired it up? I exactly want to have the same behaviour. I want to use the factory logic and enable the aux light to come up as an option together with the high beam.
It's easy to do, mount the relay under the RHS wing at the edge of the engine bay, take power and earth from the positive post near by. Use one of the original power wires for the driving lights as the signal wire for the relay and take the DRL feed from the DRL's on the RHS headlight. its at around 3:20 in the video I made on my mods.
View: https://www.youtube.com/watch?v=_ep5ht5KxqU
