Triple R / LAZER Sentinel Grill Lights
Fishnerd
3:30 AM
Seattle
Finally got the Triple R (aka LAZER lights) Sentinels Installed. Pretty straight forward install. Only nerve racking part was cutting the grill, but they supply cutting guides which made it pretty easy. I converted to deustch connectors and wired to switchpros instead of overhead console.
img_4377-jpeg.7897406
Cheers!
View attachment 7897407View attachment 7897409
Cheers!
Wonderful. They are the next upgrade for my truck. I will wire them for amber DRL and I quite like the Euro option of having them come on or not when the main beam is triggered.
View: https://youtu.be/U3MzxT66S4w?si=vgjd2VnFIJbRacAR
That’s what I have done with mine..amber drl and wired to original Aux light switch.
I might ask to rack your brains re wiring etc. I am not much of an auto electrician.
Guess need to order the £1128 ones;
No Problem, interestingly my vehicle differed from the one Lazer used in the installation video. I ended up mounting the relay in a slightly different place. The wiring colours for tapping into the headlight loom were also different.. It’s all worked out well though, I’ll get some video of it at some point. At this time of year it doesn’t get dark till really late I might have to wait up LOL.
Awesome! I did the amber as well. I considered using the aux switch, but opted using the switchpros for ease of use and options it provided. I also wired the drl’s so I can turn it off and on whenever I wanted
Awesome! I did the amber as well. I considered using the aux switch, but opted using the switchpros for easy of use and options it provided. I also wired the drl’s so I can turn it off and on whenever I wanted
that looks very neat indeed 👍
I just tried them out, I am very impressed! What I like most is the spread and the colour of the light. It really does look like sunlight, I took a few pictures with my phone but you have to zoom in to really appreciate the difference. I suspect because the phone camera is compensating for the additional light. To the naked eye there is a much bigger difference. I'll take some more with the DSLR with the exposure locked and see what that looks like.
Update: I checked the info on the iPhone shots. The Sentinels were at half the ISO and nearly twice the shutter speed.... That explains a lot
Here's the pictures anyway..below is : Dip, Main beam and Sentinels
mmmm Sentinels......
You sir are an engineer, I'm wobbly at best with my Makita. Think I'll use my hacksaw to start. I may have to dm you some more mid build/demolition!
Also took your advice;
Were you able to fit the yellow lens covers? I was considering getting them but wasnt sure if it would clear the housing?
Good question. I bought them but on reflection I don't think they will fit in the housing. I might send them back. Will let you know once have a definite answer.
