Transfer case oil change procedure
Just got done doing the front and rear diffs.
Lots of metal shavings in there as has been reported. My rig is right at 2,100 miles. Glad I got this done. Both the fill and drain plug magnets were not visible, covered with metal dust and small particles.
Did the transfer case a week ago. The oil in there was clean and probably didn't really need to be done.
No way I would have wanted to wait until the factory recommended 10K mile service for the diffs.
I can see from you profile picture that your "Solihull product" has turned you into a master mechanic how far from full do you have to fill the diffs as I think its not fill to spill .
True, but I also said that this first measurement was not exact. But actually this measurement doesn't matter at all. If 2.1 liters come out and 2.1 liters have to be refilled according to the table, what else do you want to measure?
I'm more interested in the reason for such a low oil level. Since I can't answer that, I sent an email to my dealer today and asked him about it. If I get an answer, I'll share it.
Can i ask how you changed your diff oils?
Was it simply loosening the diff inlet nut, removing the diff drain plug to drain the old oil, and then refilling with the same amount of diff oil that was drained, after re-plugging the drain outlet? And then putting the inlet nut back?
Thanks
That's exactly how I did it. A further inquiry through my dealer at Ineos also revealed that only 2.1 liters should be filled. This is definitely less than if you filled it up to overflow as usual. Why this is so has not been answered. The question of whether a special tool is needed to measure the oil level was also not answered. Basically, it's not a problem to fill in just 2.1 liters, but then you should also give an understandable reason why you're doing it differently than the rest of the manufacturers. However, it would have been more service-friendly to arrange the inspection opening on the differential so that it is filled up to the overflow. That would have cleared up any misunderstandings. But that seems to be the new motto: Why keep it simple when it can be complicated?
I referenced the "Quick Reference Oils" guide that has been posted here. I also measured the amount of fluid drained and topped off back to the same amount. About 2 Liters of oil drained from both diffs and about 1.75L from the transfer case.
The diffs are definitely not "fill to spill" per the 2.1 liter spec. The level is about an inch below the fill port when properly serviced.
Thanks
Thats exactly right. Super easy job. Its a bit tight to use a ratchet and socket so I wound up using a 12mm Allen key to loosen/ tighten the fill and drain ports. Measured the fluid drained which was right at 2 liters, then used a hand pump to refill. About a 20 minute job per diff.
The transfer case required an 8mm allen socket. Lots more room there so a socket and ratchet were good to go for that job.
Just a thought .....you might want to check the true volume for the transfer case oil change to take account of the additional amount required for transfer case cooler;). When my t/f case was exchanged for a new one as part of a recall over a year ago, the tech. who undertook the job advised that the new t/f case was "overfilled" from the factory to take account of the t/f case cooler volume.
Reactions: S52
Yeah I think I accounted for that by measuring the amount of oil drained from the T/Case and refilling the same volume of fluid. It was about 1.75 liters. Understanding that some fluid was likely trapped in the oil cooler circuit.
A helpfully tech told me 22mm below on rear and 32mm below on front diff are correct fill levels. Mark and measure with an Allen key. He said overfilling tends to come out of the breathers.
Thanks for the tip. I'll give it a try. Just make sure the (rear) handle of the measuring tool / Allan key is long enough so it doesn't accidentally fall into the differential while measuring. I removed my original diff breathers and relocated them up into the engine bay.
Why don’t they like this information available to everyone? I know some people who will fill to spill these things..
Back to transfer cases, I had a similar experience to Greasmonkey: when I removed the transfer case filler plug fluid gushed out as if the level was quite a bit higher. I quickly did it up a few threads so I didn't lose much and undid the drain plug. The 15000 kms service doesn't require the transfer case oil to be changed but while all the tools were oily I thought I might as well do the transfer case as well.
As this was the transfer case's first oil change the level should have been at the factory set level. The drained oil was about 2 litres. The pump nozzle was just a bit bigger than the filler hole but sealed reasonably well so I was able to put the recommended 1.8 litres in and quickly reinstall the filler plug but the oil level was still higher than the filler hole - or the oil inside the cooling system is at a higher level and at least some of it will drain out if you leave it draining.
The oil pump I have delivers 100cc per stroke, which makes measuring easier. The diffs took 2.1 litres each - 21 strokes - and the level in both was 23mm below the filler hole with this amount.
I was surprised that the recommended lubricant for the transfer case was 75w-90 and not 80w-90, the same as the diffs. 75w is much thinner to make cold shifting easier in manual gearboxes, hardly a concern in a Grenadier transfer case.
Interested in what oil pump you’re using?
It doesn't have a brand but it is just a generic oil pump for 20 litre drums that I bought to service my Robinson R22 back in 1989. It has a plastic circular "nut" around the inlet pipe, and a thumb screw to tighten it, that goes around the inlet pipe. Once the pipe is inserted all the way into the 20 litre drum, the "nut" is screwed onto the drum and the thumb screw is tightened the setup is pretty stable and can be pumped with one hand. But if you're careful the inlet pipe can inserted into smaller plastic containers - 1 litre, 4 litre et cetera. A second person to pump the handle or hold the oil container helps when using it in this way. The hooked metal outlet at the end of the delivery hose has a threaded section on the end that can close the outlet completely or tighten it around a standard grease nipple.
