- Local time
- 12:02 PM
- Joined
- Oct 2, 2023
- Messages
- 699
It just showed up on my Trialmaster. I outlined the scenario in a previous response to my response. ^In the build or did you add it afterwards?
Sorry - just saw that. So yeah, $800 in build vs a quoted add price of $4500 - there has to be a misunderstanding. I’ll find out on Monday unless someone else has the chance before thenIt just showed up on my Trialmaster. I outlined the scenario in a previous response to my response. ^
I inquired about adding the tow package after the fact before knowing my Grenadier had one and told it was "impossible" possible v. $4,500?Sorry - just saw that. So yeah, $800 in build vs a quoted add price of $4500 - there has to be a misunderstanding. I’ll find out on Monday unless someone else has the chance before then
Sounds like we have the exact same setup and needs, so let’s see if they give me a similar number on Monday. I added the hitch receiver for my bikes, and would only imagine a light utility trailer, kayak trailer, or small fishing boat for inland species. Not towing a large boat, horse trailer or RV.I do have the receiver and hitch already. I believe that was $500, and was added before I took possession (I needed it for my bicycle rack). I was also expecting something in the $800 range to add the wiring kit. I'm not towing anything that requires anything beyond lights so the module is overkill. I plan on just adding aftermarket wiring myself at some point for way less money.
Hello OscarGood morning Guys and Gals in the INEOS Grenadier & Quartermaster world with no trailer wiring or hitch. I have a solution to your problem. I now have hitch and as close to a plug and play solution that you can get to….what do you think ?
Hello Oscar
Can you tell me more about your hitch set up.
Do you have a electric harness too,
If so did you install it yourself, or did Mossy.
Our dealer here in Florida insist the harness and computer update is just around the corner, any body has some update on all of this hitch problem
Thanks
Good evening,Hello Oscar
Thanks
Sounds like a reasonable price. So this does not include an electronic brake module, correct - just running lights, brake lights, turn signal?Good evening,
Please find attached photos. The hitch and wiring are sold as a package and individually.
The package includes the following: receiver hitch, mounting hardware, all wiring and connectors. 795.00 plus tax and freight. Installation 200.00.
Pretty straightforward install with instructions provided to self perform.
Hitch and mounting hardware / 375.00 plus tax and freight
Trailer wiring package -425.00 plus tax and freight.
We have installers in Texas only at the moment.
We will be at the INEOS Moab event in May. If anyone needs any of the above I would be glad to bring product and do field installation while at the event. Please email any questions to me at
Marty@offroadgearguys.com
or give me a ring 361-254-1427
Correct.Sounds like a reasonable price. So this does not include an electronic brake module, correct - just running lights, brake lights, turn signal?
Hello Oscar 3rdGood evening,
None of this kit is IneosHello Oscar 3rd
Thank you for your valued information,
I assume you order this directly at Ineos, would you have the part numbers.
Also does this installation interfere with the much talk about computer i.e. flash out of sync or throw errors.
Thank you in advance
Peer (Salted Fynbo)
Hello Oscar 3rd
Peer (Salted Fynbo)
CorrectSounds like a reasonable price. So this does not include an electronic brake module, correct - just running lights, brake lights, turn signal?
We have the hitch, and complete wiring harness.Hello Oscar
Thanks
