Stop using "one-size-fits-all" tire pressures - a science based guide to the right tire pressure
not the most common size to find, especially if you're up in load index 108 for that kind of load. I don't think you can even buy that tire in the US.
Very common size in the UK, most of the big trailer manufacturers use it, ( Ifor Williams et al). The tyres though are all common trailer brands but usually south Asian manufacturers.
yeah i saw them in europe. i just did a cursory look but i could not find that size tire in that load factor in the us. I didn't look super hard though...
Am I reading this chart correctly? With a Grenadier at the 3400kg to 3500kg weight range with the OEM spec BFG 265/70 r17 tyres That I would be overweight for the ideal tyre pressure at highway speeds.
You can’t set an “ideal PSI” on a tyre that’s at max weight is my take ?
edit. To add to my confusion. These tyres have a maximum weight bearing capacity of 1450kg each so well within the max vehicle weight of 3500kg for a Grenadier.
At that weight you're right at the limit, 3.3 bar or 48psi. Remember i added in a bit of safety buffer for leaky tires and poorly calibrated tire pressure meters.
It's that buffer gets you over the limit. But strictly speaking you're right up near the limit with no buffer. I tend to want to have a bit of a safety margin so you're seeing that.
I could redo the table and eliminate the safety margin if it's misleading or creates concern.
No it’s OK I think there is enough safety margin. I was probably nearer 4 tonnes in Africa at times. Only issue was in deep sand at lower pressures where tyres were getting too hot. But that was travelling in mid afternoon heat, so extreme.
The factory 17” BFG KO2 tires are load range E, with a max load of 3415 lbs @ 80psi. @parb , are you using the load range C numbers in your table?
Good catch! it comes in two load ranges at that size, E and C. I picked the wrong one. Lets me redo the table.
Edit, table redone for the correct load rating. i added an explicit table highligting the load ratings used for each tire. Because the higher load rating comes with a stiffer sidewall the entire table had to be recomputed.
Likewise on the factory installed 255/70 18” KO2s Load Range is D at least on my 24 MY unless they’ve changed the specifications for newer production models.
I didn’t realise freedom units were different from British imperial units. See below. Wow.
Freedom units" is a term for the US Customary System, similar but distinct from the British Imperial System, both stemming from old English units, with key differences in volume (pints, quarts, gallons) because the US didn't adopt the Imperial system's 1824 reforms, making US units generally smaller for volume, while both are non-metric systems largely replaced globally by the scientific Metric System.
Freedom Units (US Customary)
* Origin: Pre-1824 English units kept after US independence.
* Key Feature: Different liquid volumes (e.g., US pint, gallon) than Imperial.
* Examples: Feet, pounds, US gallons, US fluid ounces, Fahrenheit.
Imperial Units
* Origin: Standardized British system from 1824, replacing older English units.
* Key Feature: Larger liquid volumes than US Customary (e.g., Imperial pint is 20 fl oz, US is 16 fl oz).
* Examples: Miles, stones, Imperial gallons, Imperial fluid ounces, Celsius (used alongside).
Key Differences (Volume)
* US Pint: ~473 mL.
* Imperial Pint: ~568 mL (20 Imperial fl oz).
* US Gallon: ~3.785 liters.
* Imperial Gallon: ~4.546 liters (about 1.2 US gallons).
Hi @parb step 2 still needs to be edited as it still references KO2 tyres with a 117 load rating.
Regards Logsplitter
you're right, i made the cheat sheet use the right tire i should probably have done the same in the example.
The example has been corrected. i had the entire document proofread by an external source who knows the space for math and rule of thumb correctness.
