Stop using "one-size-fits-all" tire pressures - a science based guide to the right tire pressure
not the most common size to find, especially if you're up in load index 108 for that kind of load. I don't think you can even buy that tire in the US.
Very common size in the UK, most of the big trailer manufacturers use it, ( Ifor Williams et al). The tyres though are all common trailer brands but usually south Asian manufacturers.
yeah i saw them in europe. i just did a cursory look but i could not find that size tire in that load factor in the us. I didn't look super hard though...
Am I reading this chart correctly? With a Grenadier at the 3400kg to 3500kg weight range with the OEM spec BFG 265/70 r17 tyres That I would be overweight for the ideal tyre pressure at highway speeds.
You can’t set an “ideal PSI” on a tyre that’s at max weight is my take ?
edit. To add to my confusion. These tyres have a maximum weight bearing capacity of 1450kg each so well within the max vehicle weight of 3500kg for a Grenadier.
At that weight you're right at the limit, 3.3 bar or 48psi. Remember i added in a bit of safety buffer for leaky tires and poorly calibrated tire pressure meters.
It's that buffer gets you over the limit. But strictly speaking you're right up near the limit with no buffer. I tend to want to have a bit of a safety margin so you're seeing that.
I could redo the table and eliminate the safety margin if it's misleading or creates concern.
No it’s OK I think there is enough safety margin. I was probably nearer 4 tonnes in Africa at times. Only issue was in deep sand at lower pressures where tyres were getting too hot. But that was travelling in mid afternoon heat, so extreme.
