Steering dead zone
rob88
9:19 PM
United States
Well, have to throw in my two cents. The steering definitely has a large dead zone. When the truck needs a minor steering correction due to wind or road crown, etc, the correction may require rotation through the dead zone before the minor correction can be made. As a result the wheel is moved more than it should have to be for small correction that otherwise might not annoy. It is better than some trucks I have owned, but also worse than others. It seems like it should be resolvable and I hope Ineos or aftermarket do just that.
In the mean time I am getting good at making the correction, but it does keep you busy on the freeway. For such a tight truck, it is surprising to me that this is the case. This does not condemn the truck in my view, but it can (and I am sure will) be better!
I had my tyres rotated balanced and an alignment done a couple of months ago.
Before then, I had about a centimeter of wobble in the steering, maybe less. Since the alignment it’s three times that, and because of that I get the sense on the highway the car is all over the road. It also feels like I am constantly pulling it back straight against the camber of the road.
In fact, if I take hands off the wheel it tracks dead straight and true for as long as I leave it. But because of the “dead zone” as you call it, it feels like it’s all over the road and I’m therefore doing little corrections all the time. But I’m not really. Because the steering wheel’s vague my mind plays tricks and thinks it has to correct all the time.
So, I’ll need to get that sorted, and it could well be your issue as well.
The above notwithstanding, I also believe you need to drive the grenny like you steer a boat. Early slow inputs rather than quick sharp ones, which it doesn’t like at all. Get that into your mindset, and it’s great to drive.
Sounds like a typical steering box characteristic; the UK MOT examiners handbook gives different tolerances between steering boxes and rack and pinion steering.
"Steering wheel free play should not be more than:
13mm for rack and pinion steering, or 48mm if there are several joints between the steering wheel
and the rack
75mm for non-rack and pinion
These limits are for a standard 380mm diameter steering wheel. The limits should be adjusted up or
down accordingly with larger or smaller diameter steering wheels."
It is all too easy to 'overdrive' a vehicle with a steering box, you need to relax into it's working characteristics. Having said that, you do need to separate between working clearences and excess wear.
Can’t say mine does that. Nor did the loaner I got in namibia. I installed the Bilstein steering damper (thanks Rohan) and it’s been even more excellent since that, but I can’t recall ever experiencing that dead zone you mention. Namibia highway driving was often at 166kph (hitting speed limiter) yet held the road just fine. Might be wheel camber/caster etc maybe needs changing ? Or something else different from mine - MY23 Trialmaster in Australia.
I had a bit of freeplay and needed some minor corrections at speed on a motorway. I’ve now had the wheels balanced and alignment done. Steering is now much better with no dead zone.
Could be an alignment issue. Some early trucks had caster set too low from the factory. The Bilstein damper helps, but getting the caster checked and adjusted might fix that dead zone for others.
Not the balancing nor the alignment have anything to do with free play on steering.
Do you have the alignment report? Check it against factory specs. It may have results that reduce slightly directional stability and thus you feel the need to make corrections. Experienced alignment shop can improve it even within tolerances on the factory sheet.
Same here.
It's been through 3 alignments. The wheel track is true, but on the road at highway speeds the center marker on the steering wheel sits a few degrees off to the right with a very prominent dead zone.
It bothers me, but not enough to worry about wasting time on bringing the truck in.
30,000Km on BFG KM3's with a few rotations in between. No uneven wear. So for now not a problem.
I tell ya, its been 6 or 12 months that I've spent any time on the forum, and today after sinking a few hours into various threads it would seem there are a fair few issues Ineos needs to sort out. My truck included! :LOL:
Replace the steering damper and get an alignment. I did this early on and the dead zone disappeared. I recently had a loan QM which was stock and it had a big dead zone, plus the steering wheel was about 20 degrees to the left when driving straight.
Edit: I did not describe that as well as I should have, the dead zone on the loaner was from about 20 degrees left on the steering wheel to centred. On my daily drive to work the wheel was mostly at the 20 degree left mark on straight roads with regular rotating back and forth black & white movie style.
Unfortunately recirculating ball steering suffers from this problem compared to the more common rack & pinion and electronic assisted steering used on most SUV's
That's one reason most now use independent front suspension. So they don't have to use recirculating ball steering.
Lots of comments about Ineos choosing this system because it is better offroad.
They chose a solid front axle first and that meant they had to use recirculating ball steering.
It is discussed in the early Ineos videos from back in 2002
The video below is a good but basic explanation of how each system works.
View: https://www.youtube.com/watch?v=G6Hv6_mwkB8&t=84s
Mine behaves the same as yours.
I am used to it now and just don't do the minor corrections
I've decided to go with the Tough Dog steering damper.
It's an Aussie company, was in stock, has adjustability, and is 1/2 the price of the Bilstein. Plus it seems like everyone has good things to say about it.
I'll report my findings here once its installed.
There are other options outside of recirc ball. There are also lots of recirc ball trucks that don't have this issue.
I installed one about 6 weeks ago, not because I had issues with the factory one but because my wife didn't enjoy driving it around roundabouts en route to anywhere.
Figured it was a cheap experiment.
It's as loose or as tight as you need it/ want it to be, easy to adjust and the dust cover won't ever make the clang sound.
Like others here, I use it on setting 5 most of the time. Less than that is too loose for gravel roads.
