Steering and suspension geometry setting details
Just FYI, you cannot change one side without the other following. Meaning what ever the caster is on the right then the left will always be the same. You can cause some bushing bind at best and maybe cause the axle to be a bit out of line with the chassis but that is marginal if much at all. But so long as you adjust both sides at the same time and the cam or eccentric bolts are in the same general orientation then your fine. But again you cannot have one side of the truck with say 1.5° of caster and the other with 3°. That's impossible unless you broke your axle in a wreck. Any delta between left and right is either alignment machine error or tolerance maximums from Carraro.
Agreed, tolerance changes would be minimal and as I mentioned “slight”. The only risk you’d run, as you mentioned, would be the potential of one cam adjusted a little ahead or behind the other taking the axle slightly out of line but it would be within the gross tolerance specifications. Assuming you loosen both caster cams at the same time adjusting them will make the entire axle rotate to the new caster angle if you keep them both in the same orientation.
Either way, I’d still make the changes on an alignment rack to ensure axle remains straight with chassis and to watch and record your final caster settings and verify all other angles. After all, you are there making changes anyway so check everything so you know what you have and then drive and see if you like the caster changes you made.
yeah but really doesn't show you much expect which one's to adjust... usually they show you how to exactly do it, but probably liability on this one
Update:
Had owner/tech Doug @ Truline align the Grenadier. Doug knows the IG as Ineos Seattle uses his services at his Seattle location.
He nailed it. Steering is really tight and straight. I love that he was able to max out caster a bit beyond stock range.
Update:
So rides better? Also does it matter one is 2.46 vs 2.49?
I c
Update:
I could be recalling this wrong, but I believe the max spec for Ineos was 2.5°. Mine is at 2.6-2.7°. One of the Vendors claims they are hitting 3°
