Grenadier. I can't remember if you bought one.Getting what?
AWo
AWo
Well I have 8 ; before the Grenadier project I had no desire to buy anything built after 1995. (My wife buys new cars)Ah...see, we own 10 cars,
Yeahh, good engines stopped beeing availabe after the 1990ies. The 1990ies was the best decade for cars, i.m.h.o.Well I have 8 ; before the Grenadier project I had no desire to buy anything built after 1995. (My wife buys new cars)
But the Grenadier was cool and different. I never thought I'd see the like of it in my lifetime. But here we are , all smiles , despite the price.
Classic Boss Mustang 429,If, at all, the next car will either be a Toyota Land Cruiser or a Ford Mustang, but that is the choice of my wife, as she loves both cars.
Do they serve outback Australia?Call Sahara Assistenz, Douz, Tunisia, they'll charge about 3000 to 5000 Euros.
I lived 3.5 years in Tunisia a long time ago, have been in Douz several times.Call Sahara Assistenz, Douz, Tunisia, they'll charge about 3000 to 5000 Euros.
It was a pleasure to me to save you marriage.
BTW: Porsche is special, yessssss......
AWo
we really need access to information like this, do you have a work around for someone like myself to be able to get shop information on these rigs?I have the info!!
First, can you elaborate on what you are feeling going from negative to neutral toe. I'm considering a touch of positive toe.Question: Does the IG come with caster adjustments? If so, any pics showing where or how?
Another kind member sourced this somewhere, but the toe values are not the same as the one shared in this thread.
I just had it aligned with 0 toe and it drives worse than before which isn't a surprise, but surprised to see a source that lists 0 toe as spec.
Back to the alignment shop I go as it came with some negative toe from factory.
I'm hearing people pushing 3°. Honestly the more the better. But that is at the sacrifice of the drive shaft CV angle at the transfer case. 2.5-3° should be plenty if all else if proper. I believe the max limit from Ineos is 2.7° but I could be wrong.Owl calls for 2 degrees. Has anyone else done this? If so how easy is it.. thanks
With 0 toe, there was a lot more play in the center of the wheel at all speeds. At .16-.17 positive front axle toe (in spec), the truck drives with less micro steering input required at all speeds going straight.First, can you elaborate on what you are feeling going from negative to neutral toe. I'm considering a touch of positive toe.
Second, the caster adjustment is done with the lower arms. There are adjustment cams at the frame side. It's a very typical setup.
It's a very easy process and the bolts have a torque spec. But, it does kinda require knowing what you are doing and an accurate angle gauge to actually set the caster to a specific setting. That said with the Grenadier you can set it to max and be confident it's set pretty much where you want it.anyone got a video showing how to adjust hte bolt for us rookiesis it just as simple as tightening it down to max or more precise which means bring to a trusted tire shop
You can adjust the caster eccentric bolts yourself visually but wouldn’t recommend it. There are enough tolerance differences at the attachment points, bushings, eccentric bolts themselves, etc… even if you got them visually adjusted the same you’d still be off slightly side to side. The vehicle really needs to be setup on an alignment rack so you can watch the changes being made “live” and set to the correct nominal specifications.anyone got a video showing how to adjust hte bolt for us rookiesis it just as simple as tightening it down to max or more precise which means bring to a trusted tire shop
