Statistics/Poll Thread: Front driveshaft CV joint failures
Year: 2024
Model: Station Wagon Trialmaster
Suspension: Stock. FWIW, equipped with factory winch (I understand that this modifies the stock front springs)
Type of failure: torn boot at transfer case
Mileage at Failure: 7,500mi. Found by dealer. Requested they check common failure points while the truck was in for the software update. They must have known to look exactly there.
Warranty: Covered, but they only replaced the boot, not driveshaft
Driving: Purchased used at 7,300mi, unsure. Appears not to have been offroaded (at least not primarily).
Year: 2024
'Warranty: Covered, but they only replaced the boot, not driveshaft'
Well that's an interesting development. The driveshaft is catalogued under a single PN. The only parts breakdown is the slipjoint boot (-043970) and the screws.
I wonder if IA have purchased and shipped out a bunch of boots for doing hotfixes if the CV is still serviceable, or did this dealer get creative?
A couple of comments from chatting with IA at the Perth 4WD show today. I'm just relaying the comments made and won't be getting into a debate.
  • How the lift kit is installed will have an impact on the CV joint boots. Correct method is to use spring compressors rather than dropping the axle to install the springs. Axle dropping will likely damage the boots and in particular the rear one at the transfer case.
  • The limit of travel of standard front shocks protects the CV joints. Fitting longer travel shocks will result in the boot being damaged over time.
  • Off the record comment was that properly installed with std shocks lifts up to a 50mm should be OK.
Cheers
Steve
Cheers
Steve
That’s got me thinking 🤔. So maybe the CV joint failures on stock vehicles as mine is, could be attributed to not using the correct procedures when working on the vehicle. Mine had been in the Ineos workshop two weeks before it failed. I’ll never know but if that is the case then I can feel reassured that this shouldn’t happen again if correct workshop procedures are followed. 🤞🏼
Cheers
Steve
As axle dropping is probably quicker than using spring compressors, I would anticipate that many 'upgrades' will be damaging to the boots. The truth or otherwise could be evidenced if we do not see too many repeat failures, assuming the correct replacement procedure is followed, (which is not a given). The second bullet point gives a little insight into the interconnection between running gear choices - it isn't always a zero-sum game and the law of unintended consequences applies.
All geographys have their own issues, but I have never seen the need for a lift in the UK and I have seen too many vehicles being ruined by big lifts for the look and not much else. All vehicles are a series of choices and compromises, so it is easy to "break the envelope" - a lifted truck has a higher CoG, so roll will be exaggerated and on-road handling compromised.
Cheers
Steve
Point 1&2 have long since been addressed. Most installers have realized that you must remove one side of the drive shaft to install springs. Functionally no different than using a spring compressor when it comes to the shaft. And I don't know any shocks that are longer than stock aside from the kings. A simple limiting strap could solve that issue with kings though.
The 3rd point, well sure, but that's still 2". Most people except us early adopters of Eibach have not exceeded 2" and still have multiple failures.
So my conclusion is that the person you spoke with has very limited knowledge of what's really going on.
100% on that. And their still having failures with no lift. What percentage is the unknown and is it a matter of not IF but WHEN regardless if you have a lift or not.
Failure: c-clip transfer case end front drive shaft. Happened when pulling out of a junction. High range not locked.
Year: 2023
Suspension: no lift
Mileage at Failure: 13,150 miles
Warranty: Pending
Driving: 50/50 on/off road.Written to IA: yes - stating this is now a known problem and real risk of this design flaw leading to danger to life and limb etc etc
edited to change boot failure to c-clip one
Failure: CV boot transfer case end front drive shaft. Happened when pulling out of a junction. High range not locked.
Year: 2023
Suspension: no lift
Warranty: Pending
C-clip failure. Your boot looks fine.
UPDATE: it went into the shop on Thursday and by Friday morning it was determined that something in the transfer case (high range side) is failing. The “clunk” does not happen in low range. There is only 5 degrees of driveline “take-up” in low range (normal) and nearly 45 degrees of FRONT shaft rotation until take-up in high range. I suspect I’ll be getting a new t-case. Again, only 5100 miles (with about 500 miles of Colorado off-road use).
FINAL UPDATE
It wasn’t the front driveshaft, nor was it the transfer case. It ended up being a bad U-joint at the front left steering knuckle. So, they replaced both that and the axle in one assembly. Drives like new.
edited my original post to show likely c-clip failure and stating have written to IA requesting their immediate attention due to possible danger to life caused by this now known design flaw.
Been inferences a couple times now on the forum of a potential change, maybe with the 24.2 or 25 MY. Wonder if it’s possible to nail this down to model year/version? My dealer claims not to have seen any on stock suspension trucks and was pretty adamant that the issue is caused by dropping the axle when installing new springs in that it is causing issues with the boot. They don’t drop axles when installing new springs.
Year 2023 /11
Stock Standard
40.000 km
15.000 km Off road driving in Centre Australia
Warranty refused due to airbags in the back
And how do they claim the air bags are related to a common failure point?
Is the car lifted or standard spring height?
Year 2023 /11
Stock Standard
40.000 km
Front or rear shaft? Airbag in rear would be a tough denial of warranty if it was a front shaft.
