Statistics/Poll Thread: Front driveshaft CV joint failures
Year: 2024 Station Wagon
Miles: 5100
Suspension: STOCK
Failure: As indicated by service manager: “pronounced/severe pre-failure ‘clunk’ when getting on / off throttle” at low speeds.”
Went in the shop today. Awaiting result. Meanwhile enjoying a QM loaner.
UPDATE: it went into the shop on Thursday and by Friday morning it was determined that something in the transfer case (high range side) is failing. The “clunk” does not happen in low range. There is only 5 degrees of driveline “take-up” in low range (normal) and nearly 45 degrees of FRONT shaft rotation until take-up in high range. I suspect I’ll be getting a new t-case. Again, only 5100 miles (with about 500 miles of Colorado off-road use).
New tcase for sure. cheaper to replace than tear apart. Keep us posted… These transfer cases appear to be relatively bomb proof/gear driven. Curious to the failure point.
Failure: CV boot transfer case end front drive shaft
Year: 2024
Model: Station Wagon
Suspension: Lifted 1.7/1.2 inches, installed at 8,000 miles
Mileage at Failure: 12,500 miles
Warranty: No
Driving: 98% road mostly 50+ mph; a 2% off-road 3 trips to Moab / other parts Utah
Is the excessive rotation with the CDL unlocked in high and low range?
2024 Quartermaster
35mm Eibach lift by dealer
Transfer case end boot failure at about 25000kms. Replaced shaft under warranty
Then had 50mm lift as part of a gvm upgrade. Diff end boot failed roughly 2000kms later. Replaced with rzeppa joint and put original (35mm eibach) springs back in front end.
Have put another 15000kms on since and still good
Year: 2023
Suspension: 30mm Eibach kit + Rear Air Bags. Installed at 5,000 klms
Mileage at Failure: 15,000 and 45,000 klms
Warranty: Yes x 2
Driving: On-Road, 10% 3.5t Caravan Towing/Off Road
Boot failure both times. Transfer Case replaced at delivery, Rear Shaft has been replaced, as well as Front Diff.
Year: 2023
Warranty: Yes x 2
😳 so you've had 2 x CV boot failures, transfer case, rear shaft and front differential replaced
Year: 2023
Suspension: stock
Type of failure: circlip failed leading to stripping of splines in CV joint at transfer case end.
Milage at Failure: 30,000km/ 18000 miles
Warranty: Waiting on confirmation
Driving: 90% on road, but failure happened during steep low range work.
Updated info below. Please report if you have had an issue. With a very small number reported, it’s impossible to interpret any trend thus far. If you hear or see a report of someone’s problem, please encourage them to report on this thread. I won’t include third party reporting in the numbers.
Note - I’ve not sorted by year. At least not yet. I will if a trend seems to be developing.
SW stock failures 6
Avg mi : 14,871
Replaced under warranty: 100%
SW Lifted failures 10
Avg mi: 15,417
Replaced under warranty: 30%
QM lifted failures 1
Avg mi: 15,534
