Statistics/Poll Thread: Front driveshaft CV joint failures
Year: 2024 Station Wagon
Miles: 5100
Suspension: STOCK
Failure: As indicated by service manager: “pronounced/severe pre-failure ‘clunk’ when getting on / off throttle” at low speeds.”
Went in the shop today. Awaiting result. Meanwhile enjoying a QM loaner.
UPDATE: it went into the shop on Thursday and by Friday morning it was determined that something in the transfer case (high range side) is failing. The “clunk” does not happen in low range. There is only 5 degrees of driveline “take-up” in low range (normal) and nearly 45 degrees of FRONT shaft rotation until take-up in high range. I suspect I’ll be getting a new t-case. Again, only 5100 miles (with about 500 miles of Colorado off-road use).
New tcase for sure. cheaper to replace than tear apart. Keep us posted… These transfer cases appear to be relatively bomb proof/gear driven. Curious to the failure point.
Failure: CV boot transfer case end front drive shaft
Year: 2024
Model: Station Wagon
Suspension: Lifted 1.7/1.2 inches, installed at 8,000 miles
Mileage at Failure: 12,500 miles
Warranty: No
Driving: 98% road mostly 50+ mph; a 2% off-road 3 trips to Moab / other parts Utah
Is the excessive rotation with the CDL unlocked in high and low range?
