Statistics/Poll Thread: Front driveshaft CV joint failures
11:02 PM
Virginia, USA
CV failures
Station Wagon:
2 Stock, 18,062 average miles at failure, 100% covered by warranty
1 Lifted , 18,000 average miles at failure, 0% covered by warranty
Quartermaster:
Stock - 0, 0 average miles at failure, % covered by warranty
Lifted -0, 0 average miles at failure, % covered by warranty
This first post will be updated with a running tally of failed front drive CV joints for information purposes for the good of the community. Please do not use this thread to discuss causes, ideas, replacements, Fosters, or which tire width is preferred. There are other threads for that. If I’m missing an important data, please let me know.
If YOU have a failure, please add a post on this thread with the following information:
Year, model, stock or lifted suspension (if lifted, how much, and approximate mileage lift was installed), mileage at initial failure, did warranty cover repairs, and type of driving (ie, 20% heavy off road, all road miles, etc.), and type of failure.
Year: 2022
Model: Station Wagon
Suspension: Lifted 2 inches, installed at 5,000 miles
Mileage at Failure: 18,000 miles
Warranty: No
Driving: 50% off-road, rough trails
Year: 2023
Model: Station wagon
Suspension: stock
Type of failure: Lubricant leaking from the end cap.
Mileage at failure: 13,000km / 8125 miles. Monitored then replaced at 21,000 km / 13,125 miles
Warranty: Yes
Driving: On road
Model year 2023
Build date 19/01/2023
First registration 09/05/2023
Station wagon
Stock suspension
Roughly . 28k miles
complete cv joint failure caused I’m told by C-clip failure causing damage to gearbox, transfer box cable, oil pipelines and thermostat, heat shielding etc. . Ultimately new gearbox, transfer box cables etc .
This happened two weeks after a service at around 30mph On a tar road.
Repaired under warranty.
Model year 2023
Station wagon
Stock suspension
Roughly . 28k miles
complete cv joint failure caused I’m told by C-clip failure causing damage to gearbox, transfer box cable, oil pipelines and thermostat, heat shielding act. Ultimately new gearbox, transfer box cables etc .
This happened two weeks after a service at around 30mph Ona tar road.
Did the warranty covered all related repairs?
2024
Wagon
Stock suspension 35” tires 255/85r17
12,000 miles CV boot rip. Front driveshaft replaced under warranty
Daily driver with about 15 percent off road use including use that fully articulates suspension
Year: 2022
Warranty: No
😳 Wow year 2022 build in the USA. Is yours a prototype Grenadier. ?
2023 wagon
Suspension lifted at around 10000kms and 295/75 tyres
CV transfer and diff boot failed at 56000kms a mixture of lots of HWY and Outback travel.
No warranty, well actually no interest from dealer, both failed 300kms after major service…
Model year 2023
Station wagon
Stock suspension
Roughly . 18k miles
Boot split + leaking front & rear diff seals
Front Propshaft and seals being replaced under warranty on 3rd Nov - done 2k miles since identified (told it was OK to keep using)
95% On Road driving including many long Motorway trips
Note: Mine is an early build and the transfer box was replaced on recall at around 4k miles
Year: 2022
Model: Trialmaster wagon
Suspension: 2-ish inch, installed at ~500 miles
Mileage at Failure: 26,000 miles
Warranty: ? Fixed myself. T/C boot torn open about 500 miles after recent service.
Driving: 90% on road, highway high speeds
2024 Grenadier
Lifted 2.5" apparently according to my Owl Invoice.
King Shocks
Lifted at around 3000miles
Stock joint failed around 7k miles
Terra Joint failed at just over 14k miles
Installed new joint at 14,350.
No attempt at warranty due to lift and joints are cheap enough.
Admins, can you grant access to me to continue to edit my first post so that numbers can be updated as posts are made? For some reason I can no longer edit the post.
CV failures
Station Wagon:
4 Stock, 16,531 average miles at failure, 100% covered by warranty
4 Lifted , 21,449 average miles at failure, 0% covered by warranty
Quartermaster:
Year: 2023
Suspension: 2.5 lifted (Eibach springs, stock shocks)
Mileage at 1st failure: 8000km Warranty: Yes
Mileage at 2nd failure: 24000km Warranty: No
Driving: 95% On road
Year: 2024 Station Wagon
Miles: 5100
Suspension: STOCK
Failure: As indicated by service manager: “pronounced/severe pre-failure ‘clunk’ when getting on / off throttle” at low speeds.”
Went in the shop today. Awaiting result. Meanwhile enjoying a QM loaner.
First US deliveries were Nov. 2023 and considered 2024.1 model years.
Me - Dec 2023 build / Feb. 2024 delivery
Stock suspension and tires (on diff wheels)
12,000 miles - no issues thus far (edt - no drivetrain issues - HVAC on the other hand...)
Year: 2024
Model: Trialmaster
Suspension: 1.7" front / 1.2" rear, installed at ~12K miles
Mileage at Failure: 13K miles - Boot failed
Warranty: Denied due to lift. Replaced with Rzeppa joint.
Driving: 95% on road, highway high speeds
