Starter Battery Drain; How to stop ECU's etc from consuming battery when door opens?
- I constantly hear a high-pitched beeping sound from a control unit
-> When this occurs, the SOC has also dropped significantly. SLEEP mode does not seem to work here, but the question is which control unit
I have the same and described it before somewhere here. I noticed, that this does not occur when i turn the ignition on again for a second after shutting down the engine.
I don't what is causing this, i would call it a high frequency Sound, barely noticable.
Hi, thx for your answer. so much content here.... :-)
I also can notice this high frequency sound even unlocking the IG... very strange. may a find the time to identify the area and other things around this.
replaced it with a Redarc ALPHA 50 R
They seem so be hard to find on the web. Can you tell where you have bought yours and what the price was?
Hi, yes. I orderd the REDARC in Germany @GPC offroad, but also Taubenreuther is a dealer.
The mounting bracket I ordered from GP Factor from the US.
I can post some photos if I find a bit time :-)
That high pitched noise sounds loudest by the rear left hand wheel (diesel). Maybe fuel lift pump?
I notice the high-pitched sound on left of the vehicle too when locked. I routinely experience up to 20% battery loss overnight if I forget to double-lock it.
I recently had a loan vehicle as mine had more issues to resolve. This loan vehicle had the same problem! Mine does not. I felt it was something to do with the power steering, electrically powered for sure (e.g., could occur with engine off) and when moving the steering wheel you would here this change… perhaps related to power steering>
I’m having pretty significant issues with my factory 2battery set up. Overnight with the car locked, no auxiliary power going out or anything I can lose up to 10% on the dual battery system. Last night it was 72, wake up to drive down at 63. It’s also charging at a rate of amps quite often 2 A or less… and furthermore I’m struggling to ever see more than 82%… But when I first got the car it was in the high 90s
My car is going back to the dealership, I have to get this solved. I travel a lot and the two battery set up was a big selling point…
Not sure if this has been fixed yet, but i had similar issues, which were solved when i switched my batteries. Then i replaced the ctek system with a redarc alpha r to manage my solar and aux battery, but the drain and poor alternator charging was already solved. Pictures of current setup are here https://www.theineosforum.com/threa...ed-not-disappointed.12416228/#post-1333289791
The pictures don’t appear to be working on the thread you posted. Would be interested in seeing what you did!
interested, every time i unlock my car i hear a sound from under the engine bay. I've heard it when opening the hood. its towards the left of the engine when looking into the engine bay from front. closer to the windshield, somewhere behind the jumpstart terminal. Seems to be intermittent and completely go away after about 2-3 minutes.
I've been racking my brain trying to figure out what is going on. Doesn't sound like a pump (eg gas pump or something like that). More of a buzzing sound than a whining sound.
Is it high pitched? When I unlock my truck I hear a high pitched squeal-almost like the PS whine. Always assumed it was the fuel pump.
I get it on my diesel as well, I'd put it down to something energising, or coolant being circulated through the turbo.
According to google on the B57 engine, it’s the high pressure fuel pump in the diesel at the top of the engine.
The carabiner idea worked. Only it needed to be in the door latch. Thanks @HereinDaRockies.
I am fairly sure the HP fuel pump is engine driven.
I’m no expert I’m afraid but according to google your right it is engine driven. So what is the high frequency whine when you unlock the car? Would it be the actuators for the EGR?
My guesses are...
Low pressure fuel pump
Electric coolant circulation pump for the EGR cooler
Electric coolant circulation pump for the turbo
You don't.
But If I am working on it in the garage all day, at least the battery doesn't drain.
You only have to let the vehicle sit for 15+ minutes with whatever doors you want open. I verified this by disconnecting the batteries. Keep in mind that once the system is asleep, with say only the cargo doors open, opening a closed door will wake the system. When I did my solar wiring I left both cargo and both rear doors open so I could work on it as time allowed.
