Starter Battery Drain; How to stop ECU's etc from consuming battery when door opens?
I have added a Victron Smartshunt to my starter battery so I can see the current drain when the vehicle is off. This allowed me to quantify how much current is drawn when you open/close any door etc. Basically, what I found is that opening any door will start a 15 min cycle. The overall power consumed in this 15mins is 0.4Ah. Any door open (or close), will put you at the start of this cycle. The vast majority of the power is consumed in the first 3 minutes, however, it takes the full 15 minutes to go to a full power down state. Having the overhead PWR switch on burns a constant 0.33A (my guess this is the power for the USB charger etc).
The Battery in the car is a 105Ah rated battery. The lead acid battery will not get fully charged from driving as it takes many hours to go from 80% to 100% charge. So, it will likely reside around 80% charged. The lead acid battery is effectively depleted at 50% charge. Therefore, there really is only around 31.5Ah of usable power before you will have trouble starting the vehicle. With each door open/close consuming 0.4Ah, you can do this 78 times before draining the battery. If the PWR switch is on (with no other switches on) It will consume the 31.5Ah within 4 days.
I have looked into what fuses can be removed to eliminate the door opening current. In all cases I waited 15 mins for the current to go to its lowest state (20mA) before pulling any of the fuses.
I tried the transport fuse (FC04) Cockpit electrical, this does not work.
I tried the Door Lock (FI20) Interior Electrical, this will kill the locks, however, does not work at stopping the door opening current.
By pulling Body Control Module 1 (FC05) and Body Control Module 2 (FC06) it is possible to stop the current being consumed as a result of door opens. I tried removing only one of them, however, it seems that both need to be removed. There is a couple of side effects of pulling these fuses from a camping point of view.
1. You can't lock the doors (need to put the fuses back in to do this, not that big of a problem in my opinion).
2. the overhead PWR switch will not turn on.
I hope this may be helpful.
Regards,
Carpetman
More details on the fuses can be found below.
Regards,
Carpetman
It’s amazing how stupid Ineos has implemented the electronics in this car
WE NEED A FIRMWARE FIX
Sounds like INEOS needs to offer a camping mode on the console, select it and the car shuts a lot of these systems down. Even better if you could select which systems to shut off in camping mode. Turn off camping mode when you go to leave.
Does leaving a window open, instead of a door, make any difference to power consumption?
Having an external power source you can access without opening doors will help. I have an external 50 amp Anderson I can access off the aux battery and some of the devices I plug into the rooftop power outlets have their own switches )no need to turn on/off using overhead panel. So I can make some behaviour changes to minimise power loss. But the biggest thing I did was add that solar panel as it seems to cover these power drains fairly well.
Regards,
Carpetman
Thank you, great information.
It also explains why you use so much battery power when working on the car and opening doors/bonnet for an hour or two - the car never goes to sleep.
MY SETUP
Does your car have dual batteries? My car has the OEM dual batteries; a CTEK 120S and 250SE; and a roof amounted solar panel (160W).
I had the 250SE and solar panel installed. Using an external 7 stage battery charger, last week, my main battery was very close to 100% after 45-60 minutes. It was only on bulk charge a few minutes, and the last 6 stages were done in the remaining time. I did not check often enough so I do not known if the external battery charger stopped at around 45 minutes or 60 minutes. The two weeks before this I had done mostly short trips, mostly under 10 minutes.
It strongly suggests my setup is keeping the main battery well charged. My solar panel study showed the main and aux batteries were being charged by power from the solar panel, as discussed here with graphs supporting that observation.
I'm sure leaving a window open will not have any impact on the power consumption. From what I see, leaving the car locked vs unlocked has no impact on the power consumption on my car.
I have changed my solar so I can charge either battery, and I added a trickle charger as well. I therefore expect that I will not be having issues this summer. See Electrical Setup
Regards,
Carpetman
Here is the powerdown current profile - very similar to the door open.
I just tested this door behavior today. It’s egregiously stupid:
driver and passenger doors are both open for many minutes. infotainment has already turned off due to inactivity.
I’m done with with passenger side so I close the passenger door (driver door is still open).. that action alone triggers the infotainment to boot up.. 🤦‍♂️
wtf were they thinking ?
Don't know if this has been suggested before:
What if one would disable all the door switches, I mean wiring them hardware-wise so that all time closed doors are reported to the Chinese software.
Should be relatively easy. The only drawback I can think of at the moment would be that it takes a few seconds more till the engine can be started?
Chinese software? Details?
In camping mode, the consumers (the socket in the boot, the USB ports, the PWR and the EXT/INT switch) can be disconnected from the system and connected to a lithium power bank instead. This would mean that the power bank would supply the boot socket, USB ports, PWR and EXT/INT switch rather than the starter battery. The power bank can be charged using a distributor such as the CTEK 250S, the alternator, or optionally a solar panel.
Have I made a mistake?
IMHO this would not solve the problem: "open/close a door => start all control units (and possibly energize the glowplugs, not sure on this...)"
"Neusoft" Please google for details.
EDIT: Thanks @Clark Kent , recalled from memory, would have had difficulties to quickly find this page again...
Well there you go. Should I be concerned, remotely?
Only if Neusoft were engaged to develop and deliver the software then released without a maintenance contract. But that's nothing to do with being a Chinese company. If IA purchased the source code or it's held in escrow then it doesn't matter who did it - competence aside...
If you're the type who likes to worry: Just do it ;-)
Seriously, has anybody thought about rewiring the door switches?
Thought about it, but then I was thinking how long it would take to boot up and pull out without it. It seems to me the issue the gren is a modern car, and you're not going to get completely around that fact.
I’m having pretty significant issues with my factory 2battery set up. Overnight with the car locked, no auxiliary power going out or anything I can lose up to 10% on the dual battery system. Last night it was 72, wake up to drive down at 63. It’s also charging at a rate of amps quite often 2 A or less… and furthermore I’m struggling to ever see more than 82%… But when I first got the car it was in the high 90s
My car is going back to the dealership, I have to get this solved. I travel a lot and the two battery set up was a big selling point…
I had thought of that but for other reasons. Where would these door switches be located.
