Solar charging of primary battery
I need some help with my battery setup. I have a Trialmaster with the Ineos factory dual battery system. I have a Victron MPPT connected to the secondary battery. My fridge is connected to run directly off the secondary battery. My roof outlets powering my camp lights still run off the primary battery. The guy who did the installation for me told me that once the secondary battery is fully charged via solar, it will also charge the primary battery via the solar input. I don't see any charge going into my primary battery even though the second battery is full. From what I can see on the Internet, the Smartpass completely disconnects the 2 batteries when the engine is off. So it seems unlikely that primary battery will get charged. When I connect my AC charger to the primary battery however, it does look like the Smartpass allows charging of the secondary battery. Is that correct? I don't have much time before my next trip, and is looking for a quick and simple solution to allow charging of my primary battery as well with solar while in the bush, as the camp lights draw a lot of power from my primary battery.
So from my discussion with Ineos technical this morning, it sounds like they are not only dropping the option of the second battery in new models, but you will also no longer be able to see battery SOC or voltage on the screen.
That’s a shame. I find that quits useful. I suppose it’s down to owners to do their own thing as regards second batteries and battery monitoring.
Battery monitoring is a cheap fix if they do pull it from the software. I always hated having to start the engine to check SOC anyway.
Bit of advice needed. So I’ve got the Alucab lifting roof conversion and I’d like to add solar to the roof. Cabling with an Anderson connector at the roof end is already there and cable down to the battery box.
I’m considering a 270w semi flexible solar panel on the roof linked to a Victron 100/20 mppt solar controller connected to the main battery. I’m happy with the current dual battery system of the Grenadier and no plans to change that. I also still have the option of using my 2 x 100w suitcase style solar panels when parked up and camping for extended periods.
Any thoughts welcome please.
I am not sure exactly what feedback you want, but ensure the voltage and combined amps of the two solar panels do not exceed the ratings of the Victron solar regulator.
My setup is similar. I have a CTEK 120S mated to the 250SE, with a 180W solar panel on the roofrack feeding into the 250SE, plus I can use an extra solar panel at the rear of the car, again feeding into the 250SE. Solar is the Red Anderson plug. Grey is the output to any trailer or caravan. The 13 pin Euro plug was also changed.
My system is slightly different, as the aux battery is charged first, then the main battery. In the real world, the main battery gets charged most days. I can leave the car for weeks and both batteries remain in a good state of charge. The 250SE properly charges the aux battery.
Towing pack details here. Solar panel performance here.
In my ski boat I installed a Renogy 30 amp DC to DC charger with a lithium aux battery. The aux battery runs everything expect the engine. When the engine is running the starter battery is charged from the alternator and the aux battery is charged from the starter battery. When in my dock I plug into a 100 watt solid panel. Solar charges the aux battery first and when that is full it charges the starter battery. In the case of a car with roof top solar, it can charge from both solar and alternator simultaneously.
Very nice I’ve been looking at the Renogy kit yesterday and noticed they do a combined dc to dc charger with mppt controller. It’s certainly a consideration for me. Not many manufacturers do a combined dc to dc charger with solar controller and Victron certainly don’t. The reason I have chosen Victron in the past is that we have lots of Victron kit around inc a completely off grid system and I can normally get for a decent price through a contact. I’ll do plenty of research before committing but aim to fill the roof space of the Alucab with solar.
I’ve just read in the thread ”Battery drain. What’s causing it “ that @onuraiu from Estonia is getting battery drain and one thought is that his Victron solar controller is causing it. I don’t know how but I need to research before committing to anything. As I move on to kitting out the inside of the Grenadier I may add a LIFEPO4 lithium house battery so will need a dc to dc charger as well.
I am far from an expert on anything electrical…..Anand helped me install a REDARC 150ah battery, BC-DC Alpha charger with MPPT solar controller. On the Silenus roof conversion I have 4 50watt Sunflare XPLOR Blox panels (200w total).
I too like that Renogy controller. Im thinking of pairing with their 200W shadowflux panel on the roof rack. This could make my fridge a dedicated option.
I do connect to the lifting eye as mine is easily accessible in the petrol version. Adjacent to the live post under the bonnet is a small stud that some people use for the same purpose. I think it’s the one I’ve indicated on the attached photo. Others may verify for me.
By the way I love the Khalagadi NP and have been a few times now. March 2023 was the last time on the Botswana side.
Fwiw this is where I mounted my trickle charger Euro style connector. Seems to work well.
It’s been working well on my boat. If it can live on a ski boat that spends the summer in the water then a car interior is cake.
I like that unit, as well as the Rover 30 and Victron 100 | 30. I really only need the MPPT function so I’m opting for smaller size. Tonight I’ll dig around looking at potential mounting points. Can the solar controller be mounted under the rear seats or does it need to be in the open to cool?
They want a little room around the heat sinks but I think under the seat is likely fine.
I fabricated a custom mount for the center space under the rear seats. It consists of two formed aluminum strips that leave the center open for air flow. The Victron and a 20A fuse fit perfectly.
It feeds the starter battery and I’ll start to collect charge data tomorrow (cloudy with some rain forecast).
