Slashing water noise
BillLumberg
Forum Donor
1:07 PM
TN, USA
I have done research on this form and the Internet and ChatGPT, but none of them seem to have the answer. I have a slashing water noise in the back of my Grenadier. It sounds like I have a cooler half full of water making noise. I have pulled multiple drain plugs fold my floor mats up and I cannot find where I’m retaining water anywhere. Any help or advice would be greatly appreciated. Thank you.
Someone had some water trapped in a chassis rail, from memory. They removed a bunge from the chassis and it drained out. EDIT: Look here:
There's a service action bulletin for rear cross member water ingress - see your dealer.
To allow for the installation of a side roof awning, the roof hand rails were removed and reinserted on the LHS of the vehicle. The following day it rained and I had the sloshing water sound from the rear left of the vehicle. I found the water was located in the compartment under the car jack. I drained the compartment and had the roof hand rails removed and the area resealed, which solved the problem.
I found the chassis rail post and removed the plugs, but no water there. I think the rear cross member might be the issue from where I am hearing the noise. Calling tomorrow. Anyone had this service done? Any details?
I believe I’m suffering from the same problem and I’m 1000 miles from the closest dealer, please keep us updated
There is a TSB for the roof panels leaking, the water pools in between the body and the fender liner. According to my dealer, there is a drain plug in the fender liner.
