Side steps/Sliders, Homemade and I ask you for help
Paco Garcia
10:16 AM
Valencia (España)
In the end I decided to make some steps in a friend's workshop that would in turn provide some protection for the bodywork. I have them almost done but when I went to plan the attachment points, a problem arose: the support points of the The ends that are in the car have through holes so you have to put screws and threads, but the central support are threaded holes and I can't know what thread and pitch it is, I have tried with metric 12 but the thread pitch is not Valid, metric 10 is small, can someone help me with this information. What type of screw is appropriate? Thank you
PS: I leave you a photo of the projectEstribo casero.jpg
Rab
9:16 AM
N.Ireland
Standard M12 pitch is 1.75, these are metric fine so M12 X 1.5 pitch.
Paco Garcia
10:16 AM
Valencia (España)
Those look like Buzz Overland Rock Slider / Steps. DaBull
196 / 5.000
Resultados de traducción​
Resultado de traducción​
Yes, I needed the height of the footprint to be 41 cm, and at the same time for the rest of the step to reach the top, I didn't like the original ineos ones, they look very low, greetings
DaBull
1:16 AM
California
196 / 5.000
Hi Paco, Great minds think a like. Having a robust rock slider that also allows an ease of entry step height into the vehicle is a win win in my opinion.
Once you get these mounted and finished and the vehicle off the lift let me know the following measurements:
1) Step height from the ground to the step at both the front drivers step and passenger step.
2) Ground clearance from the ground to the bottom of your rock slider at both the front and rear.
3) Overall thickness of your rock slider at it's thickest point, (not where step is).
4) Photo of it installed and off of lift so we can see the whole side of the Greanadier with your rock slider.
Thanks in advance. DaBull
Paco Garcia
10:16 AM
Valencia (España)
No Problems DaBull, it will take me a few weeks to finish it, I am leaving tomorrow on a trip (10 days of Skiing) and I will resume it when I return, but as soon as it is finished I will send you photos and the measurements that you ask me for here. Greetings Paco
Regalz
2:16 AM
Colorado
PS: I leave you a photo of the projectView attachment 7839484
The front 4 are threaded as well and smaller than the three in the center
Paco Garcia
10:16 AM
Valencia (España)
That’s odd
It also seemed strange to me, and given your statement I have checked the front mounting plate again and we are both right, there are 8 holes, four through holes and four with welded threads above Metric 10. Thank you (y)
Paco Garcia
10:16 AM
Valencia (España)
Bueno amigos por fin los terminé, hacer trabajos así es un poco tedioso a veces, pero bien está lo que bien acaba, les dejo unas fotos del proceso y listo. Saludos Paco
IMG_1619.jpgIMG_1621.jpgIMG_1622.jpgIMG_1623 2.jpgIMG_1625 2.jpgIMG_1627.jpg
Esta ya terminadas y fuera del elevador
IMG_1675.jpgIMG_1676.jpgIMG_1677.jpgIMG_1678.jpgIMG_1679.jpgIMG_1680.jpgIMG_1681.JPGIMG_1682.JPG
y este último dedicado a DaBull
Da toro, el perfil frontal mide 7 cm. Haz tus cuentas, espero tus comentarios, críticas, etc. Un abrazo. Paco
Jiman01
4:16 AM
USA
That looks great!! The 3cm difference from front to rear...is that because of the suspension?
donnygreygrenadier
4:16 AM
View attachment 7842743View attachment 7842744View attachment 7842745View attachment 7842746View attachment 7842747View attachment 7842748
View attachment 7842749View attachment 7842750View attachment 7842751View attachment 7842752View attachment 7842753View attachment 7842754View attachment 7842755View attachment 7842756
Beautiful job - well done!!
Jean Mercier
GG#920
10:16 AM
Sint-Martens-Latem, Belgium
El resultado final es magnífico! Felicitaciones 😍
DaBull
1:16 AM
California
Hola Paco, gracias por esa Dedicación. Eres demasiado bueno. Me encanta la construcción combinada de control deslizante de roca y escalones laterales. Pasé 2 semanas en España en 2016, un país tan hermoso. Tendré que planificar otro viaje de vuelta y parar en Valencia para saludarte en persona. DaBull
Hello Paco, thank you for that Dedication. You're too good. I love the combined rock slider and side steps construction. I spent 2 weeks in Spain in 2016, such a beautiful country. I'll have to plan another trip back and stop in Valencia to greet you in person. DaBull
DaBull
1:16 AM
California
Hi Jiman01,
Yes, like Paco I have taken detailed measurements and found that from the front door to the rear door the Grenadier has a rake of approximately 3cm or 1.18".
I believe it is the way the suspension is set up to give the Grenadier a rake to perhaps make it look like it is going faster or to make it more streamline, LOL.
I believe Eibach or another manufacture is going to be offering different coil springs providing different lifts for the front and rear in order for the Grenadier to
set level and have no rake. I kind of like the wedge shape for now, LOL.
DaBull
