Thank youYou can try to print with a gcode file from Prusa Slicer.
You have to configure "Organic Support" (Print Settings/Support material/Style)
Calculated Print Time round about 1Day 7Hours
Prusa Slicer can work with other Printers, see below.
View attachment 7852513View attachment 7852514View attachment 7852515
Installed an aluminum storage bin over the wheel well. Picked it up on Amazon but available on eBay as well. It was pricey at $300 shipped but I’m very pleased with the quality and fit. Less stuff flying around the rear now… can still lash things down using the MOLLE panel design, it would seem.
Came fully assembled. 5 minute install - you simply replace the tie downs with supplied hardware. Done.
My bison gear shelf that mounts to the roof arrives Friday…….
Sounds like a good “how to” post is coming our way!Indeflates are out of stock in the UK, so I made my own. Worked out a lot cheaper too. View attachment 7857044
You're pretty handy by the look of that and you even managed to fit a Makita battery into a Stihl chainsawIndeflates are out of stock in the UK, so I made my own. Worked out a lot cheaper too. View attachment 7857044
Its a Dolmar, (owned by Makita) the scabbard is Stihl... Well spotted! Handy little saw actually.You're pretty handy by the look of that and you even managed to fit a Makita battery into a Stihl chainsaw![]()
I don't know about Germany but if you parked that in most places in the UK, it would be nicked quite quickly.Finally I found an adequate "Protector" for the tow ball.
View attachment 7858012View attachment 7858013
I fear this will happen!!!I don't know about Germany but if you parked that in most places in the UK, it would be nicked quite quickly.![]()
Perspective..Finally I found an adequate "Protector" for the tow ball.
I like that! Did you make or buy it?
