Roof rack can and fitted today from Roof Rack City, very easy instal and I use the ceiling winch to take it off while not using it.Rola quote $1890. Where did you get yours?
How do you like their ACS/Active Cargo System on their Load Bars? Is it restrictive in any way? I'm thinking not on their Load Bars since you can simply pull off the plastic end caps easily to insert any length bolt you like as long as the bolt head fits in the slot. Unlike if you went with their full or 3/4 rack which the plastic end caps don't exist as each cross-bar is closed off by the rack's frame which I do not like. Load Bars are their recommended solution for a RTT or a ski box & IMO will be easiest to remove by a single person if & when needed.Update here…
I just keep loving the Leitner system even more. A 12mm wrench and loosening 4 nuts makes it really easy to take the two bars, toolbox, and water tank off as 1 piece to store in the garage. I just leave the mounting brackets on the Grenadier. I also needed to empty water tank and toolbox first so it was light enough to lift up a few inches to remove from the mounting brackets.
It’s great having T slots on all 4 sides. I’ve encountered 2 types of restrictions so far, neither are deal breakers for me, but more of like things to be aware of.How do you like their ACS/Active Cargo System on their Load Bars? Is it restrictive in any way? I'm thinking not on their Load Bars since you can simply pull off the plastic end caps easily to insert any length bolt you like as long as the bolt head fits in the slot. Unlike if you went with their full or 3/4 rack which the plastic end caps don't exist as each cross-bar is closed off by the rack's frame which I do not like. Load Bars are their recommended solution for a RTT or a ski box & IMO will be easiest to remove by a single person if & when needed.
Also, the load bars won’t work with the Clevershade Ultralite awning - or with Leitner’s gear pods. You have to have the rack for those. The load bars are still better for my purposes.How do you like their ACS/Active Cargo System on their Load Bars? Is it restrictive in any way? I'm thinking not on their Load Bars since you can simply pull off the plastic end caps easily to insert any length bolt you like as long as the bolt head fits in the slot. Unlike if you went with their full or 3/4 rack which the plastic end caps don't exist as each cross-bar is closed off by the rack's frame which I do not like. Load Bars are their recommended solution for a RTT or a ski box & IMO will be easiest to remove by a single person if & when needed.
I've had the Bison for over a year now. It works great.Anyone out there have the Bison-Gear or Big Country 4x4's full or 3/4 racks? What do you like & dislike about them?
The Big Country's is out of Austrailia & is 100% welded.
Bison Gear 3/4 Roof Rack - INEOS Grenadier
Upgrade your INEOS Grenadier with the Bison Gear Roof Rack – lightweight, aerodynamic & perfect for off-road. Discover ultimate functionality now!bison-gear.com
Roof Rack Ineos Grenadier | Big Country 4x4 Australia
Construction: Fully welded aluminiumbigcountry4x4.com.au
I decided to go with Leitner Load Bars & will eventually add a RTT. I was wondering the width E to W of this rack to see what size I had to work with.I've had the Bison for over a year now. It works great. View attachment 7898651
Can’t beat the factory Rhino Rack.
what grill guard is this?I've had the Bison for over a year now. It works great.
How bad do those shine through the safari windows?
It doesn't cause an issue with me. It's not like turning on a dome light/interior light.How bad do those shine through the safari windows?
