ROOF RACKS
Rola quote $1890. Where did you get yours?
Roof rack can and fitted today from Roof Rack City, very easy instal and I use the ceiling winch to take it off while not using it.
anyone know if Voager will be out with their rack soon? I really love the old school look and no one seems to be doing this.
Update here…
I just keep loving the Leitner system even more. A 12mm wrench and loosening 4 nuts makes it really easy to take the two bars, toolbox, and water tank off as 1 piece to store in the garage. I just leave the mounting brackets on the Grenadier. I also needed to empty water tank and toolbox first so it was light enough to lift up a few inches to remove from the mounting brackets.
How do you like their ACS/Active Cargo System on their Load Bars? Is it restrictive in any way? I'm thinking not on their Load Bars since you can simply pull off the plastic end caps easily to insert any length bolt you like as long as the bolt head fits in the slot. Unlike if you went with their full or 3/4 rack which the plastic end caps don't exist as each cross-bar is closed off by the rack's frame which I do not like. Load Bars are their recommended solution for a RTT or a ski box & IMO will be easiest to remove by a single person if & when needed.
Anyone out there have the Bison-Gear or Big Country 4x4's full or 3/4 racks? What do you like & dislike about them?
The Big Country's is out of Austrailia & is 100% welded.
It’s great having T slots on all 4 sides. I’ve encountered 2 types of restrictions so far, neither are deal breakers for me, but more of like things to be aware of.
#1 They have to be positioned at 1 of 6 mounting points. That’s like 15 combinations, but if you can’t make one of them work, the OEM ones that clamp onto the gutter are 100% adjustable.
#2 They are 2” thick, so if you are using mounting hardware that came with what you’re trying to mount, it might be too short. My 10 gallon water tank has brackets that clamp around a load bar, not using the T slots for that, and I had to run to Home Depot to get longer bolts.
Also, the load bars won’t work with the Clevershade Ultralite awning - or with Leitner’s gear pods. You have to have the rack for those. The load bars are still better for my purposes.
I've had the Bison for over a year now. It works great.
How bad do those shine through the safari windows?
It doesn't cause an issue with me. It's not like turning on a dome light/interior light.
It lights up road and trees ahead so much that a little light spilling into the cabin is nothing.
Off
On
I just scooped up the Big Country full length roof rack last week. I came from a modified full length Leitner, which was great too, but I wanted a true flat platform.
The Big Country is built tough! So far I love it.
I was hoping someone with the Rhino Rack Load Bars with the Rhino Rack 270º Awning can share their experience. I live in New Zealand, so it is not possible to get all the options from after-market manufacturers that others have access to. I have safari windows, so a full length Rhino Rack Roof Rack is not ideal for me.
As I can order the Rhino Racks gear from INEOS, and if it is good enough, then this is what I will do.
Thanks in advance - stephen
So something a bit different.
I wanted a basket/tray rather than a platform.
Ended up with 3x Thule ProBar Evo bars and a Rhino Rack AT alloy tray (2180mm). The tray was on Clearance - ~$330 - so all up ~AUD1,000.
The Thule bars have a "vertical" gutter - ideal for extra eye hooks as tie downs
How is the Rola Titan working out for you?
I purchase one several months ago online direct from Rola for $1800 (The Titan was a better length for me than the GrenX/Rhino option and also cheaper).
However, I was not very impressed with the Rola quality in terms of structural integrity as soon as it was mounted... The Ridge Mount is OK (although after 5,000km and sun, the stick-on rubber pads on the grab handles have turned white), but the real issue is the flex in the platform mounts and the subsequent squeaking and rattle even driving around town. I have since added a lightbar to the front edge, and it is unusable due to the vibration (the light beam projects such a bad flicker from the vibration, that it could trigger epilepsy!)
Would not buy again. For comparison, I had a Kings platform on my LandRover Defender for 15 years and is was very solid and never had an issue, and was only several hundred dollars. For the price of the Rola, I'm more than disappointed. All bolts and fasters are tight. The Ridge Mount bracket is tight. I have now inserted rubber wedges between the Ridge Mount and the platdorm to dampen some of the flex, which has reduced the rattle and movement for now. Hope they don't fall out on the first corrugated trip.
