Switch the roof plugs (ext2/3) on. Connect anything electrical (light) with a Deutsch DTP plug to the roof outlets. Or use a multimeter.Without having accessories with which to test them, what's the best way to check?
It should be noted that the OP most likely has a MY23 vehicle (as does WhiteBear ), so these are less likely to be found on the MY24sLooks like one more tool to put in the bag before I fly up to Colorado Springs Friday to pick up the Grenadier. Maybe I ended up make some test leads with Deutsch DTP plug at some point.
Yep FY23 as suggested.It should be noted that the OP most likely has a MY23 vehicle (as does WhiteBear ), so these are less likely to be found on the MY24s
stupid question:Anyone figure anything out with this? I’ve got a MY24 model quartermaster not long ago (older model but brand new). No power for ext 2 or 3. No power to the fuses but all 25amp accessory fuses have continuity.
Yeah checked with both the auxiliary power switch on & engine off as well as engine on/stupid question:
Does the problem exist when the ignition/ the motor is on? Did you switched on the pwr switch when trying ext 2 and 3 without ignition?
I know that you probably did this. But if not it could be the fault of.
AgreeIf people what to use a circuit test light, use the LED version, no feedbacks like you can have using the older style circuit test lights. Downside is that LED circuits testers cost more.
Has anyone had issues with there being no power to the roof plugs (ext2/3) switches?
There’s nothing there with appropriate switches on and lights plugged or via a multimeter.
Thanks In anticipation!
I instantly get 12v, for a microsecond on the multimeter and then nothing. It's very odd. Is there some sort of diode or resistor in between the switch and the socket?
