Right side front wheel noise
scottyboy436
2:29 AM
scotland
I have been getting a strange noise from what sounds like my front right wheel , can't get a good video of the noise , as it doesn't do it constantly and not picked up with audio on my phone.
But it's like a tinny metal/rubbing noise , has any one else experienced this ?
Is it a stone trapped in the disc? What mileage have you done, and how much meat is left on the pad ( I am wondering if it is a sticking caliper ). Try reversing backwards as fast as it safe to do and the slam your brakes on, does that stop it.
Don't think so as it's not constant, I can get the noise to kick in after putting the foot to the floor but even then it's not all the time , the car has done 10k miles
How far from your dealer, that sounds a warranty job if doing it under hard accelerating. If you are South Scotland you have got Lloyd Allroad in Carlisle as a good dealer.
But then it's not every time under hard acceleration, I'll contact ineos and see what they say. My closest actual dealer would be Edinburgh but not sure if I can put my car to a service garage as there is one closer
Just went out in the car there window down , I think it's just the noise of air getting forced past the raised air intake and it's dependent on what heading I'm driving on and what way the wind is coming
I had a plastic "knocking" sound on the highway... Sounded like a loose wire or cable banging around in the front right door or wheel area. On inspection, the raised air intake has separated from the body. The lower and A pillar mounting bolts are all still tight and the intake has never been hit or knocked by anything.
hi - i have experienced the same issue - right front wheel screeches kinda noise. The first time I pointed it out to the dealer, they checked and said it was a stone stuck in the disk, but with the way the noise was "behaving" it seemed more mechanical and wasn't a permanent noise. Happened randomly and often when turning left, which puts pressure on the wheel at an angle. Dealer turned me around a few times after that because they couldn't replicate the noise when in their hands in the shop. So i was finally able to record the noise on my phone (had to turn the Bluetooth off because it wouldn't pick up noise otherwise).
Dealer / shop guys then were able to identify that when the brake disk wears, it leaves a film of metal dust that creates friction with the drum casing - apparently a "defect" that will need to be corrected. So every 3 months or so, the noise reappears, and I have to get the car in to clean up that metallic residue. I was told there is of no safety concern. They will eventually have to find a permanent fix to this - it's just that when the noise appear, I see heads turn to look at which klunker car the noise comes from. A bit embarrassing since this is a new brand. I will update as things unfold - unless someone else comments with a solution.
Mine makes the noise when accelerating usually , then stop onc win up to speed , so I wonder if that is because the dust has cleared , will need to clean it properly and see if it stops for me also
This is old but i'll reply in case it helps others. I had a very similar noise - probably the same noise. A tinny, metal tinging or ringing noise when ever i hit a large sharp bump (speed bump or washout on dirt road). There was also a metallic sound that had a rotational, scraping element to it at slow speed - could rarely hear it except at very low speeds while turning where there was something (a building/shed) nearby for the sound to bounce off. Bugged me no end, mainly because i was unsure if it was a more serious mechanical issue.
I mentioned it at the dealers while getting a service. Took 2 techs 1.5hrs but they found it - a small stone (<1cm2) lodged in a small cavity behind the front left brake disc. At slow speeds while turning it scraped,
and at high speeds when hitting bumps it bounced and rattled around creating the tinny noise. Two points to @Eric
