Replaced the OEM plugs next to the wipers
LAdrummer
11:30 AM
Los Angeles, CA, USA
I’m not sure if any other owners have experienced this but the 18mm locking plugs next to the windshield wipers keep falling out. Not so locking after all. I replaced them with 7/8” plugs from of all places ACE Hardware (USA). The new plugs won’t pop out, won’t be lost, won’t frustrate me. I did have to bore an ever so slightly bigger diameter hole. The new plugs can be removed.
All the best,
MM
Nice solution!!! I have not experienced any issues with them coming loose yet but I assume the plastic cowl/scuttle cover is the same part shared between both right LHD/RHD versions and the plastic plugs simply cover the holes for the unused wiper arm spindles locations? I haven't pulled the plugs out to inspect to see if there is anything behind them besides free air but will certainly keep this fix in mind if they ever decide to depart the vehicle. Either that, or I'll use a few dabs of black silicone on them now to hopefully keep them in place.
More info here -
Posted this in the duplicate thread…..
These silicone versions have been working well also and go in without any mods. IIRC, the original recommendation from the forum was 19mm but I accidentally ordered the 18mm. The 18mm have stayed in place and were fussy enough to get in, I don’t think they’ll come out unless you get in there with a panel removal tool.
I also bought the silicone versions following the link provided, and I do agree that they seem to fit better comparing with OEM plugs, thanks!
Ineos original plugs appear to be held by a combination of the lugs of the plug, plus what looks like old chewing gum. The heat up here makes the chewing gum pretty soft and probably the lugs too so about half the ones I’ve seen up here in the tropics have one missing - usually the one on the drivers (RHD) side. They also use the same chewing gum to glue in the washer jet nozzles. Not sure it’s the best option for hot humid regions.
Thank you to the person who found these plugs and another thank you to the person that posted the link.
Everyone should just replace these. I lost the first one and was surprised how easily the second came out when I grabbed it. It was basically held in by gravity only. The silicone replacements fit perfectly and will never fall out.
Hey @Tom109 I don’t think you can go wrong with either. I put in the 18mm and it required enough squishing to get the edges of the plastic to engage the grooves of the plugs, that I can’t imagine they could pop out. As an added benefit, you get 6 for @$6 / 2-day Prime shipping so it’s probably the cheapest mode you can do😂😂
18mm inbound today!
