Rear Wiper - No fluid
YVR_Phil
4:17 PM
Vancouver BC
Have been trying to trace the issue for a while but nothing resolved...taking it to dealer soon.
As the title says, no washer fluid to the rear wiper. Despite some suggestions - check LH footwell, connector near the tank, kinked line in the door, fuse - i'm not getting any fluid. The pump IS working as i can hear it but it's block/disconnected somewhere.
I thought i may have the issue isolated but not sure of the routing - the passenger side (RH) has a lot of fluid on the ground (Around the wheel well area) but this is delayed. I thought it may be the fluid backing up somewhere then leaking but i didn't the the REAR washer fluid routes to this side of the car?
There's a join in the pipe under the RH rear seat. The barb joint comes apart and fluid floods the RH rear footwell and undersea area.
RH as viewed from the rear of the vehicle facing forward.
I checked this, thank you. Nothing under the seat - thank good ness..
However, I did a prolonged "wash" on the stalk today. The barb in the engine bay popped off (it was secured previously) so there is a pressure build up indicating that there is either a blockage or issue downstream. I just don't know the routing to trace. Suggesting this is a dealer issue that should be figured out.
I had an issue last week with no water to washers after a long trip. I have access to the workshop manual system thanks to Ineos. I saw, when I operated the washer system, water was running out under the car on the LHS at the back of the LH wheel well, from the chassis
I worked out how to open the LHS plastic cover under the windscreen, turns out the rubber hose had slipped off the hose barb to the washers. Easy fix to push back on. Might be something like that to the rear if you have water under the car.
Mine has no water at rear screen wash. Checked and yes connector at mid vehicle next to rear seat at rear door RHS had disconnected. BUT upon reconnecting and trying the wash it popped off - indicates further problem downstream - either a kinked pipe or a blocked nozzle. Will leave it to dealers to explore next time I’m there.
PS side plastic cover on seat was a PITA to remove - middle “screw” isn’t a screw. Seems to be sort of single use clip that breaks rather than disconnects. Or am I just not getting how it works?
One of the first repairs my agent did was fix an inoperative rear washer. The repair was to bypass a section of hose somewhere between the right rear corner, flexible duct, and inside the big door.
The hose is inside the wiring harness that goes to the door. The harness is tightly wrapped and that was crushing the washer hose. The fix was to cut the hose either side of the harness entry and exit points then run a new section of hose outside the harness. That was seen as preferable to unsealing the harness to release the crushed hose.
My vehicle is an early 2023 build. VIN #1886.
Mine is around same vintage. Until moving to NZ I don’t know that I ever tried to use the rear screen wash so it might never have worked since new. Could be the same issue. Thanks.
I used small zip ties either side of the pipe joints to secure it to the connector joint barbs
