CTEK Smartpass 120S problem
Jean Mercier
GG#920
2:26 AM
Hoeilaart, Belgium
I have the double battery in my car and I have probably a CTEK problem.
My car is parked since yesterday without driving. My fridge was running, and this morning I saw my main battery was at 12V and my auxiliary at 12.80V.
The trickle charging of the main battery through the auxiliary battery doesn't seem to work.
I checked the warning lights, and according to the manual it means the auxiliary battery is too hot. But, the car didn't drive, the ambient temperature is 18°, and the battery doesn't feel hot.
Anyone any idea?
(CTEK 250 installed, but not solar panels connected)
As battery ages they can deteriorate at different rates, but if the fridge is on the main battery it maybe drawing power faster than the trickle charge from the aux to the max, via the CTEK120S.
Look at the 24 hour graphs from each battery to see if there is a variance in power draws.
Anyone any idea?
Is your fridge connected to the starter or auxiliary battery?
Interesting. I couldn’t find a description for only 2 flashing lights in the manual only 3. I also found the following document with a quick Google search which describes the LED error light flashing patterns in more detail. It’s a pity Ctek didn’t illustrate the positions of LEDs 1 to 4 but I interpret that they are the four central orange ones with 1 at the top and 2, 3 and 4 in a line below.
https://www.ctek.com/storage/28C7E7...d7c64cca8bf34ae67436258e/FAQ-NA-SMARTPASS.pdf
Perhaps the light pattern is indicating that start assist has been activated, as the Ctek manual notes a fault indication will be shown but I can’t see a matching light pattern for this in the error light section.
Cheers
Steve
I checked the temperature sensor, it was stuck on the auxiliary battery, but the car and interior and battery were cold :unsure:
On my d250 and d250s there is a temp sensor that needs to be stuck onto the battery. You seem to have a d250se (?) does this not have the same wired temp sensor?
https://www.google.com/url?sa=t&source=web&rct=j&opi=89978449&url=https://www.ctek.com/storage/C51B3E1AAB94F62928DD2ED3FED85942C07C57DA0B10D08B06A96963A7810281/00000000000000000000000000015925/pdf/media/6652a4901fd740f29693eda94efab665/D250SE-manual-low-UK-EN.pdf?srsltid=AfmBOorApyclwKpKN_a6_CxRj90VXj5v8_20PC_LIDs5gmhuLjyVKOdM&ved=2ahUKEwjUs6mO6omUAxVtdUEAHbnINUkQFnoECCMQAQ&usg=AOvVaw0sWOyx9cBLxrB3RzuYWWsp the manual seems to think there is a sensor, what have you stuck it onto. It might be in contact with something else, that is getting warm in the sun (? Guess ?)
Cheers
Steve
Steve, there is a more extensive manual of the SmartPass of 14 pages, and there you find the 4 leds error with two flashing. On the 🚢 to Spain now, with bad internet connection, otherwise I could show you.
I had looked at the patterns of both batteries, and normally the trickle charging is very noticeable but, now nothing. The auxiliary battery doesn't deplete, and the main battery depleted each time the fridge is running. Therefore I still think it is the Smartpass and/or temperature sensor failing. Once home I will disconnect the Smartpass from the battery. Perhaps a "reset" will solve the problem 🤔 . Lucky for me this happened in my last day of Morocco travel. I still have to drive to Belgium though.
Thanks Jean. Your smartpass manual must be a different edition. The PDF I have (also 14 pages) only mentions 3 flashing LEDs for over heating and single flashing LEDs for other error states. I’d be interested in seeing a copy, but there is no urgency from my side so perhaps when you get a chance after your trip.
Safe travels and I’m looking forward to more stunning pics
Cheers
Steve
I don't think the pulsing charge every 3 seconds of the smartpass is designed to help power a fridge from the start battery. More likely is there to compensate somewhat for normal self discharge rate of the start battery i.e. very low discharge and not a fridge @ 5 or so amps.. could be wrong of course. For this reason I was using the smartpass 'consumer out' until Ineos removed that option, now I run the fridge off the aux battery via a victron smart battery protect as this ensures the Aux battery will still have a state of charge to assist the start battery if required. Seems to work well thus far.
I’ve just had my car serviced from the dealer and I brought up and explained that my battery never reaches 80% Soc. I trickle charge my car overnight and it’s still sits at 75%.
As my battery is usually at 60% Soc, I’ve noticed that I don’t get a full DPF burn because the battery threshold hasn’t been reached. Usually I can tell when it’s needs a burn because the engine starts to vibrate at idle.
I been told, never trust the SOC on the screen because it’s not accurate. Apparently it needs resetting on the Ineos BMS software to tell it has a new battery. This calibrates the SOC and cannot be done by disconnecting the battery.
So I had it reset today and whilst driving home my Soc shot straight to 85% and also a DPF burn.
Did this info about the SOC come from your conversation with the dealer or what you have learned elsewhere?
I last posted about the BMS here and mentioned the need for a reset after battery replacement on BMWs. Your info suggests the same process might be required for Grenadier.
Yes direct from the dealer and only with the Ineos software too.
Yep, I have been saying that for a while. Install a cheap battery monitor and you will get more accurate information overtime. Various monitors discussed here. The apps graphing function gives you get useful insight into trying to work out any problems.
