Rear Wiper - No fluid
YVR_Phil
9:28 AM
Vancouver BC
Have been trying to trace the issue for a while but nothing resolved...taking it to dealer soon.
As the title says, no washer fluid to the rear wiper. Despite some suggestions - check LH footwell, connector near the tank, kinked line in the door, fuse - i'm not getting any fluid. The pump IS working as i can hear it but it's block/disconnected somewhere.
I thought i may have the issue isolated but not sure of the routing - the passenger side (RH) has a lot of fluid on the ground (Around the wheel well area) but this is delayed. I thought it may be the fluid backing up somewhere then leaking but i didn't the the REAR washer fluid routes to this side of the car?
There's a join in the pipe under the RH rear seat. The barb joint comes apart and fluid floods the RH rear footwell and undersea area.
RH as viewed from the rear of the vehicle facing forward.
