Power steering noise
Eric.S.
7:47 PM
Thank you;)
As a calibration exercise...is this what other owners that have the condition are hearing? Do I win a prize for the squealiest PSP?
God that is loud compounded by echoing inside the garage.
Test, do the same someone inside rocking the steering to activate the noise and put your finger over the pin hole (vent hole) on the side of the cap. See if the noise changes. I want to know if pressurised air is making the noise out of the hole.
Upvote 0
I'd like to read that spec to see how it is stated. I'd expect something like " PSP noise levels up to 75dB when measured with engine idling while rotating steering wheel using a calibrated sound pressure meter held two feet from the PS reservoir" or something quantifiable like that. Otherwise this becomes a battle of subjective calls from folks with various hearing health and maybe some motivation to fix or not.
Anyone know what that spec is so we know what "good" is? I assume its in the dealer service manual someplace?
Upvote 0
Will do! And will roll it out doors to eliminate any echo off garage walls.
Upvote 0
Test, do the same someone inside rocking the steering to activate the noise and put your finger over the pin hole (vent hole) on the side of the cap. See if the noise changes. I want to know if pressurised air is making the noise out of the hole. Also when I put my ear near the res, the whistle sound more like its coming from someplace below that level add back toward the firewall on the R/H side.
Upvote 0
No change...see attached. Also, when I put my ear closer to the area, the noise seems to be coming from below and back a bit toward the firewall on the R/H side, Not from the reservoir or the cap. I do really appreciate the constructive help here BTW.. This vid was out in the open, not in an enclosed garage. Guess its back to the shop...
  • IMG_5715.MOV
    15.7 MB
Upvote 0
Mine does not make any noise at full-lock in either direction, and noise stops 5 seconds after any steering imput. The pitch changes with steering input pressure up to full lock (then no sound).
My fluid level was already at max cold. There was evidence of over-flow, but it was also just at the dealership for 1 year service and to check PS noise so they may have spilled some.
I lifted the wheels off the ground and did 60 full-lock-to-lock sweeps to try to clear and air. No change.
Video in my garage:
Upvote 0
Video in my garage:
Sigh...that's what I'm talkin' bout. That is what it should do! So there is hope. I can barely hear the whistle but it is MUCH quieter than mine and about matched the three I listened to at the dealer earlier today.
Upvote 0
I appreciate the investigative work people are doing here as it's beyond me. I also get the steering whine (to an embarrassing level).
The only other steering related issue I have and i'm unsure if it's related but will mention - does anyone else get feedback through their steering when stopped? Like a gentle kick/rotation of the steering wheel like the power steering is trying to assist or activate even though you're not providing any input?
Upvote 0
Normal
My DILs 2002 Benz also does it.
Modern systems eh!
Upvote 0
Isn't this artifacts of the recirculating ball feedback ?
Upvote 0
Can't say I have ever noticed it on the vehicles with recirculating ball steering systems I drive daily. Might be an idiosyncrasy with electric hydraulic power steering systems when the electronics detects a steering demand from the steering position sensor and ramps up the pump.
Upvote 0
The electric pump seems like a neat idea that isn't great in practice. I am going to sound like a cave man, but someone should make a conversion kit with an engine belt driven pump to feed the recirculating ball steering box. I'd gladly sacrifice a few HP to parasitic loss for a quiet and reliable pump.
My 1994 80 series Land Cruiser has a gear driven pump (and a recirculating ball steering box) that is bombproof, and serviceable (it has over 300k trouble free miles on the OEM seals, and I can still order a rebuild kit from any Toyota dealer around the globe - on a 30 year old vehicle).
Upvote 0
@GreenGrena other than the noise, you don't have any other steering issues do you? Does it ever get firmer in short bursts? At low engine rpm?
Nope, just the noise, no other problems. Just the usual behaviors and design issues (steering wheel centering, larger turning radius, occasional kick while sitting at ide with the wheels turned, etc.) absolutely no other items I'd consider defects at all.
PS...I got a text earlier today from the local dealer that they will R/R the pump as part of troubleshooting. As I stated a few texts back, they guys at my local dealer in AZ have been great. These mfg hiccups are great learning opportunities and hopefully that will be the case here.
Upvote 0
I had an opportunity to do some testing today. I can confirm the oil level basically didn't move at all while running, driving forward/reverse, steering input, no input or full lock. The quantity did increase a bit overall as the engine heated up. I am seriously leaning towards an issue with the steering wheel position sensor calibration at this point. More digging to do yet though.
Upvote 0
Recently spoke with Sierra Ineos about the whine on my pump (you can see my original videos in the early pages of this thread). They told me Ineos will fight them tooth and nail when a customer tries to warranty a pump out due to noise. They have only been successful with a small handful of trucks that exhibited wildly louder noises than what most of us have posted here. The worst part is, for every replacement they did, the noise was still there, just a little quieter than their original pumps.
Upvote 0
The steering fluid volume definitely increases with heat and climate. The steering noise and stiffness of the steering is a lot louder/stiffer lock to lock after a long journey compared to a cold engine. The increase in fluid also leaks/mists onto the exterior of the reservoir. Why I’m not sure. 🤔 What cools the fluid? I feel the electrical motor for the pump isn’t variable. It’s full power everytime the steering is turned.
Either a bigger reservoir is needed or the fluid levels need recalibrating to the markers on the cap.
As I said before, using a turkey baster and taking out some fluid level to min on a cold engine has reduced the noise to minimal and made my steering lock to lock a lot easier and much more confidence and reassuring around corners.
This is a temporary/long term fix until Ineos come up with a fix themselves if they acknowledge the problem.
Upvote 0
