Polyair Suspension Airbags
TheDocAUS
6:53 PM
Eromanga
I had Polyair Suspension Airbags fitted to the rear springs recently. The same brand airbag is fitted to my caravan.
My car is an AU Spec Diesel Grenadier, a 2 seater fitted with a RED winch, aux fuel, roof rack and drawers. So the kerb weight is on the higher side, even in everyday use. Factory suspension is fitted with an Eibach lift kit (and now Poly Airbags).
Installer’s suggestions were:
  1. Airbags are load assist, not load bearing;
  2. Check the airbags PSI setting monthly;
  3. Minimum 20 PSI, for my car. He says the bags should fit the springs snugly. If they are under inflated, the airbags will be damaged over time;
  4. When towing inflate airbags to 40-50 PSI;
  5. Maximum PSI for the airbags is 60 PSI; and
  6. Minimum is 5 PSI, but the minimum is dependent on the weight of your car - so my minimum is 20 PSI.
I just now noticed the link in your original post—apparently my eyesight isn’t what it used to be. Thanks for the kind reply!
Your eyesight is fine.
After I added links to my second post, I thought it made sense to add them to the first post.
The airbags have stopped some of the body roll when cornering - unexpected bonus. This slowly creeped up on me as I added weight to the car.
I noticed the lack of body roll when driving Rohan's car (GrenX), now the airbags have fixed this in my car.
TO CHECK
When I visit Heasemans to have the Bilstein shocks installed, I will ask whether you inflate the airbags before or after you hitch the caravan. Someone has suggested you do this before. So inflate airbags to 40 to 50 PSI then hitch up the van as the airbags fit the springs better.
