Penman Sankey Trailer with NATO hitch
HankGranada
7:16 PM
SW Germany
Hello everyone, I’ve just traded in my Defender for a Grenadier. Up until now, I was able to tow my Penman trailer with a NATO ring hitch without any issues using my Defender. However, I’m now concerned that the tow hitch or mounting point on the Grenadier might be positioned too low. On the Defender, it only worked with a height-adjustable setup as well. Does anyone use a NATO hitch on a Grenadier or have any experience with this situation? I’m worried that I might have to trade in the trailer too.
It is too low if you mount the pintle directly to the BSAU24 mount on the vehicle, you will need an adjustable mount but one that can raise the pintle to bumper level. There are two resulting potential problems. Firstly this is almost impossible using type-approved components (at least using them in a way for which they are type-approved), and secondly the pintle will obscure the number plate. If a trailer is attached then (in the UK and probably EC) this doesn’t matter, you only need a plate on the trailer, but you'd have to remove the pintle if you don't have a trailer coupled.
An alternative might be to modify the trailer so the lunette is below, rather than above, the drawbar, or to fit portal axles to raise the standard BSAU24 mount!
If we're lucky some solution will be developed for this problem since if INEOS is serious in its aspiration to bid for the TUM replacement this is a problem in need of a solution.
I have a Penman trailer which I modified to lower the lunette rung by flipping the damper and brake actuation assembly. The hitch still needs to be raised a bit but not as much.
I use receiver hitch adapters, one has a ball fitted and lowers it a bit which suits normal trailers better, and another which I use upside down (naughty I know but structurally fine) for the jaw hitch which raises it. It blocks the number plate but just clears the rear door. I never have it fitted unless I'm towing using it so the blocked plate is ok.
Tristan
That is an excellent and fairly obvious solution which is exactly what I would do. The only drawback is that as far as I know there are no receiver mounted drop/riser plates on sale in the UK or EC that are type approved, and legally on a vehicle as recent as a Grenadier type approval is required.
There are no technical, mechanical, nor safety issues involved just the legal type approval issue, but people should be aware of this before deciding how to approach this problem.
Thank you very much for the feedback! Wow — the “upside down” solution is really good. However, since I live in Germany, I don’t want to push our “TÜV” regulations too far. I will probably have to sell the trailer:-( That’s how I see the situation at the moment.
Some types of hitches are not designed to be used upside down like that. A fabricator could easily make a hitch that has a raised plate to allow for more height. But based on the previous posts I expect that would not be legal.
