Owl Vans Grenadier Steering Box Upgrade
Not true mine would squeal sitting still idling….
Mine makes some noise only when I steer and it’s not loud. I initially took it as a Grenadier thing at first to only find out the majority here are annoyed by it. Not all pumps are made the same it seems.
lol that’s messed up… you mean it never idles down after like 5 seconds of steering inactivity?
Sitting still, steering straight ahead, it would be silent, and then the pump would come on sporadically. If the wheel was turned more than an 1/8 it would squeal sitting still. In general use, you could hear me coming from a couple of hundred yards away.
A Jeep JL wrangler has a similar set up and it makes a noise. It isn’t as loud or as frequent.
If this fixes the steering whine, it will fix most of my whining about the IG. I have to think that it doesn't otherwise I'd think that would be the first sentence and major sell. But if it doesn't fix the whine, I'm thinking nothing will.... Not a steering box?
Based on the information they have on the specs, fixes the whine.
Well, folks, we have our answer on the steering pump noise. But you will have to watch to find out ;)
It’s amazing… owl can evidently spec the build of these steering pumps, without explicit requirements on noise thresholds. Even with such ambiguity on noise requirements, the supplier naturally built them in a way that doesn’t generate noise. Makes sense right? It’s like spec-ing the requirements for an order of balls, without the need to be pedantic and specify the mathematical formula of a sphere.
Ineos (and us) has the poor luck with being saddled with a dipshit supplier that took the path that results in 90db+ of shriek in many units 😭😭😂😂😂.
You almost have to explicitly try hard, to create a steering pumps that generates that much noise and then also ignore the noise while doing qc testing.
I'm encouraged. I'll want to see a few more, and have a known loud one next to one of these, inside a garage. I don't think it will be silent- the Jeep isn't silent; it just doesn't sound like there is a turbine engine in there.
I'll probably wait until spring, since I have the windows up mostly. Also hoping that some kind of deal is worked out. That Ineos just cut people doesn't make me think that they are going to do a $2K+ mod. To me the question is if they are going to use this design going forward... awkward.
Oh, and thanks OWL for taking this on!
I am likely to spring for this and have it installed in Portland. I am not bothered by the stock steering, but I do a lot of high-speed highway driving, and I imagine it would be much more enjoyable with this installed.
Honest question, if you're not bothered by the stock steering then what would the reason be to spend $3-4k to change the steering.
I'm just trying to understand the mindset of different Grenadier owners and their insistence on not calling out ineos for crap engineering and design.
Again, honest questions and not trying to bait anyone.
I assume IA would deny any steering system warranty if this new pump has been installed? Sure they may have to prove the pump caused an issue but if seals start to go or problems arise with the main steering box the pump is providing pressure to it might get a little sticky on a warranty claim.
Great question, but it seems that they were at least aware, if not actively involved.
I thought it was $2500? At that price I’ll wait awhile, if it’s over $3k, I’ll just play my stereo loud. Ride of Valkeryes.
I’ve been calling out Ineos on the power steering pump noise for a year now. No results. The response is always the same, “it’s operating as it should and unless it tests over 90 db, there is nothing wrong”
It costs nearly $1000 to have it sound tested from a private company here in LA. Even then they may not accept the results if it is shown to exceed 90 db.
I see the benefits of aftermarket parts when the INEOS offers no solution.
Bizarre video. They can't tell you whether they heard it before the video and even in the video couldn't simply pop the hood to really get to the sound. The lack of technical depth and insouciance about solving the problem gives me real pause about this company's focus and the part itself which isn't cheap.
And OF COURSE IA is going to deny warranty. They're trying to deny driveshaft warranty coverage for running 33" tires on stock suspension. lol
Regardless, I hope it works out! I'll let others beta test.
Owl didn’t design this with an explicit goal of producing a low noise steering pump. You can tell by his videos. He had no idea what we were referring to.
The pump is likely effectively silent because it takes a fucking moron to design and manufacture 10s of thousands of pumps with ear piercing whine - this shit ain’t rocket science
It’s ultimately percentage game. Whomever Owl contracted to build this is less of a moron than the company Ineos used
