NEW PRODUCT DROP - Buzz Overland's Rear Seat Delete Lite
Buzz Special Vehicles are extremely pleased to announce that we are the official UK distributor for AEV.
You can browse and shop AEV products here: www.buzzspecialvehicles.co.uk/collections/aev
New products are being listed daily so keep a look out and subscribe to our newsletter to keep up to date.
NEW PRODUCT DROP
Hey Guys, we have just released our Buzz Molle Baskets for pre order. Shipping will be Feb 2026. These can be used as standalone items or integrated into our System 3 & 4 dual drawer systems.
These make great use of what would otherwise be dead space above the wheel wells. They also feature Molle front panels with a grid pattern of m6 holes making them handy for mounting items to. Somehting unique we have don is provide provision for auxiliary power outlets and cable routing to allow hidden wiring. This is perfect for powering accessories like fridges, charging gear or anything else that needs power.
  • No-Drill Installation: Quick and reversible – secures to existing factory tie-down points
  • Full Compatibility: Perfect integration with Buzz Overland System 3 and System 4 systems. Can also be installed as a standalone item.
  • Integrated MOLLE Panels on Front Face: Enables easy attachment of pouches, tools, holsters, and accessories for quick-access customisation
  • Auxiliary Power Provision: Unique mounting points on the front face for installing power outlets (sold separately)
  • Premium 5251 Aluminium Construction: Lightweight, corrosion-resistant, and built to handle demanding conditions
Standalone / System 3 Compatible version:
System 4 compatible version:
Auxiliary Power points and cable routing provision:
Useable storage space (dims in millimetres)
Just shout if anyone has any questions.
Link to the Buzz Baskets here
NEW PRODUCT DROP
Hey Guys, we have another new release coming soon. Our interior Side Molle panels make great use of the space inside the window reveals in the boot/ trunk area. These are constructed in a way that makes them incredibly rigid so that they can take a decent amount of weight. We also run 10mm rubber bumps on the back of them so that there is no way that these can come into contact with windows. Use case for these as your a see below, makes a great spot to Mount Molle bags, Fire extinguisher and a Twin ARB Comrpessor with provision for an Apex compact air reel.
These Side Molle panels are compatible with out Buzz Baskets as well as our roof shelf. Some features that we are proud of include:
- Constructed out of 3mm 5252 Aluminium, keeping it light but and rigid
- 10mm Rubber bumps preventing any possible contact with the glass in the window reveals.
- Can be used as a standalone product or paired up with our Molle baskets (standalone, System 3 and System 4 compatible).
- Can be paired with our roof shelf also.
- Optional LED cargo light that can be switched between white and amber cane added.
- Slots around the perimeter of the Molle panel for cable tieing either wiring or airlines
- Optional Quick release fire extinguisher can be added.
- Optional ARB Twin compressor Mount and Switch Plate
- Optional Apex Compact Reel mount.
- We will be offering an inverter mount option as well with our Power Plate providing provision for 240v/110v outlets, USB & 12v Aux power, remote inverter switch and Auxiliary switch plates.
These will be launched for pre-order later this week.
Combined with Buzz Molle Basket, ARB Twin Air compressor, APEX compact reel, Fire extinguisher mount & LED Cargo light and still space for a molle bag for your tyre inflator and deflator.
Standalone with optional LED Light:
Standalone with ARB Twin air compressor, LED Cargo Light and Comrepssor Switch plate.
Let us know what you guys think. And any question fire away!
NEW PRODUCT DROP
However nice this product is, I would hate to loose the internal tie down “D Rings” on the sides of the rear cargo compartment.
Adds another angle (apologies, pun unavoidable) to this product category - always a good thing in my opinion.
When would you expect to share details regarding availability and pricing?
That’s an interesting point. What if you could just remount the d rings (assuming you didn’t run the baskets) with them? I don’t think it would take much more than a locating slot which is effectively how they interface with the factory plastics.
Hey Pipo,
We should have pricing firmed up by the end of this week which is when we’ll open up pre orders Then shipping towards the end of this month.
I would really like to see a cargo shelf about half that depth. No one is making them and I would like to have a little more vertical room at the rear and not take up the full depth of the rear.
Are you referring to the roof shelf or the mid level cargo shelf?
Mid rack, I don’t want to fully cover the rear as I will have higher items. A 30 - 38 cm rack would be perfect. Btw, please check your email Ryan 😁
Hey Guys,
Our Side Molle Panels for the rear window are no live on our website. We've added options for the fitment of the ARB compressor as well as an option to mount a 2kw inverter with our Power Plate. Thee can be installed standalone or paired up with our Buzz Baskets or Roof Shelf.
Some photos below of recent installs.
NEW PRODUCT DROP
I've got the OEM Cargo barrier, will your mounts interfere with it's placement?
@RyanT you guys really do a great job on design and implementation.
Hey Guys,
We've just released anther new product. This is for all of you that want the ability to switch out between a seat delete and your rear seats and also if you want the option to keep either the small or large seats in place.
Install is super simple. You can go from seats to the deck below in under 30min. N drilling or modification is required to the vehicle. We've used Quick release brackets on the seat bases to make getting them off quicker. Then the deck is split 70/30 allowing you to keep either the small or large portion of the seat in place.
This I now live on our website for Pre-Order here. We except to be shipping these by the end of May.
img_1795-jpg.7926777
Interesting, but no access hatch to the battery compartment(s) for maintenance like the full system has?
Each side takes no more than ten minutes to remove with a 4mm Allen key and 10mm spanner. So if you need to get into the battery compartment you’d just remove it.
