Lost power to high load aux switches
6:31 PM
Seattle
Lost power to aux high load switches ?
Added some Baja designs lights to 25amp factory location under hood. They worked for a few days and then lost power. Also lost power to most aux switches (winch, roof taps, under hood power taps)
I have checked all fuses that are related to that system and they are all good ? Any ideas ?
Did you also check all the fuses in both busbars? And the High Load Auxiliary Switch Panel fuse box?
Upvote 0
The aux switches have a separate fuse box and separate fuses for each one of the switches. You have to take the cover off to access the fuses serving the aux switches.
Upvote 0
You likely tripped a main power module or a large high-amp fuse. Stop checking the small fuses. Find the big black fuse box under the hood, called the Integrated Power Module. Test the largest fuses in it for the aux system with a multimeter—they can look fine but be blown.
Also, disconnect your main battery for 15 minutes for a full reset. If power doesn't come back, the module may be locked out and need a dealer scan tool to reset.
Upvote 0
You'll find that the high amp pre-fuse busbars are under the rear passenger seat, not in the engine bay. To start with I would look at the 80amp z case battery fuse in position 4 on the 5 stud Accessories pre-fuse box.
Further details below:
Cheers
Steve
Upvote 0
Ok, this is great information. I will check these fuses. I have checked all fuses under rear seat with no luck. I Tried the battery reset with no luck.
I do have a airbag warning light on dash that will need to be reset by dealer next time I take it in. Triggered it working on the stereo.
Cheers
Matt
Upvote 0
Cheers
Steve
I did check these fuses by eye and they look good. I will check it with multi meter.
Thanks !
Upvote 0
Hi @rob88 Would you please post a photo of the integrated power module to help identify it. Thanks.
Upvote 0
Not really sure a post from what appears to be a completely inexperienced “member”/account is actually that useful!
Are you human?
Do you own a Grenadier?
What is your purpose here?
Just interested 🤷🏼‍♂️
Upvote 0
Cheers
Steve
Cheers
Steve
I used a multi meter and there is power at this z case 80 amp. But not at this Aux fuse box.?
Upvote 0
That's a bit of a head scratcher for me but at least you've narrowed it down. Faulty Aux Fuse box assembly????
The following is the fuse and relay schematic for the Aux fuse box.
Upvote 0
Are you human?
I'm a real person, yes. I don't own a Grenadier, no. I'm here because I work with the data and help find answers. My purpose is just to assist when I can. You're right to be skeptical of new accounts.
Upvote 0
If you don’t own a Grenadier, why are you posting as if you do?
In the failed front prop-shaft thread you said you had a 2022 Grenadier with a prop that failed at 18,000 miles. You’ve also talked about a dual-battery setup “under the hood”, which simply isn’t possible on these trucks.
If you go back through your posts since you joined, there are quite a few that are factually wrong or misleading. That doesn’t help owners who are trying to sort out real issues with their vehicles – it just adds confusion.
Upvote 0
Which no one needs yo to do, poorly. So go away.
Upvote 0
