Lost power to high load aux switches
5:31 PM
Seattle
Lost power to aux high load switches ?
Added some Baja designs lights to 25amp factory location under hood. They worked for a few days and then lost power. Also lost power to most aux switches (winch, roof taps, under hood power taps)
I have checked all fuses that are related to that system and they are all good ? Any ideas ?
Did you also check all the fuses in both busbars? And the High Load Auxiliary Switch Panel fuse box?
Upvote 0
The aux switches have a separate fuse box and separate fuses for each one of the switches. You have to take the cover off to access the fuses serving the aux switches.
Upvote 0
You likely tripped a main power module or a large high-amp fuse. Stop checking the small fuses. Find the big black fuse box under the hood, called the Integrated Power Module. Test the largest fuses in it for the aux system with a multimeter—they can look fine but be blown.
Also, disconnect your main battery for 15 minutes for a full reset. If power doesn't come back, the module may be locked out and need a dealer scan tool to reset.
Upvote 0
