Looks like we have choices in US for Diff Skid Plates
I had the same issue when I installed my MetalCloak diff skids. Pulled the plastic plugs, threads were full of mud and surface rust. Had to tap the threads, 10x1.5, because the bolts just wouldn’t make it past the second or third thread All while laying on my back under the truck with not much workspace. Not too comfy, but got it done in about 5min and the plates bolted on no problem.
Same here but had to re-tap both the 10mm and 12mm threads. Just uncomfortable, and took some time. I was pleased the cheap ($20 NZD) tap and die set had the correct pitch of threads! 😁👍🏼
By the end of the day the $1000 install price was starting to look like a bargain. The cross brace and front skid were incredibly simple and quick to install, but it looks like they have some refinement to do on the rear. I didn't know when I ordered that we were getting essentially late prototype units. Owl has been very accommodating in helping us resolve issues, but there were several.
We had to drill two holes that were missing, get several pieces of hardware that were not included (mine are running without a bracket installed for this reason), and something is off with the dimensions or angle of the fuel tank skid rear support bracket. We had to apply quite a lot of force with a pry bar between the back lip of the skid and the axle housing to get holes forward of that to line up, placing the entire piece under quite of lot of spring tension. We found it necessary to start at the back of the truck and work forward due to this alignment issue. Owl recommended Locktite on the hardware but we elected for anti-seize and just ran them pretty tight. There were a couple other small refinements we passed along, but if they sort out the issues I mentioned I believe this will be a 3 hour job, mostly due to the sheer number of fasteners to work through. As it stands it took us 12 hours (with some breaks) to do two trucks.
The only other issue is an Ineos one: the threaded holes on the differential housings have plastic caps in them that probably do more harm than good by trapping water. The threads in there get rusty very quickly. My truck has a bit over 1000 miles on it and they were already rusting. Plan to have to clean those threads when mounting any diff skid.
All that said, these are extremely well conceived. The materials, welds, and powder coat are excellent. The improved cross brace really does provide more clearance in that area, but the fuel tank skid clearance as the lowest point is unchanged at a bit under 11 inches (on 35 inch tires).
Here's the vehicle side, as requested. Fasteners under the fuel tank get nylock cap nuts, I assume to mitigate risk if the plate is crushed into the plastic tank, the rest get nylock nuts. You would have to drop the plates to replace the UHMW plastic.
For those concerned about oil changes, I really don't think it's an issue.
We didn't take a ton of photos as it was a long day crawling around on the ground and we were pretty focused on getting it done. We mostly took photos for the Owl folks to reference for corrections.
I opted for black power coat, but I must say the unfinished aluminum on @ColoradoMike's is quite handsome.
Thanks for summing things up Dane! It was a fun time and you are correct...this is a time consuming job. I am very happy on how it all turned out.
Got mine installed today. Took them about six hours before I think two dudes. They said they have done a couple other people‘s installs too. I just hung out there while they did it. They had an extra office and I just worked remotely, like I do most days anyways.
I brought home my original X member. Maybe turn it into a coffee table support or something.
I took a peek halfway through the process. Looks pretty robust. I thought I had just paid for the aluminum version, but they had the black powder coated one. Looks pretty slick.
Just a guess on my part, but they confirmed that to replace the plastic parts. You’re gonna have to drop everything and then put it back in. That’s a pretty big pita and kind of defeats the purpose. My guess is the second version is going to be more plug-in play on the replacement, but just a guess on my part. I didn’t even mention that to them.
Here’s some pics of the MetalCloak differential skid plates. Made of 3/16” Steel w/ zinc coating and bent into its final shape, a lot less welds this way. Install was extremely easy once I tapped and chased the rusty bosses that the plates bolt into.
Haven’t had a chance to use them yet, but could have used them the last time out. Price was right and they are local(ish) to me.
I want to see that coffee table....
I forgot that they replace the gas tank skid plate too, that has two legs built in… I think my wife is onto me. She wanted to know why the junk parts are in the garage.
Had my IG in for windshield replacement yesterday and they did a recall on the starter wire (?) that could be rubbing, which meant that they had to move one of the skid plates. Don’t know if this is a general skid plate issue, or specific to this install.
Might want to get that done before install? Also, it seems the IG has a number of cabling/wire routing issues that could cause rubbing?
Very curious to ask this, what order of protection would you guys reccomend? I am doing rock sliders first, but have Axle protection second followed by full skid plates 3rd. My main concern is low hanging fruit such as the axle itself and the frame/ body where rock sliders will be
@Slov - I’m doing the same order like you. Installed the Rockslide Engineering slider (a pain to do it), order the Metalcloak skids and I’m actually thinking I could get by with just ordering the tank skid plate next for my needs and decide later if I need any other armor.
I have all the Agile skid plates. The diff skid plates and the gas tank skid plates are getting 90+% of the scrapes, very little on the engine skid plate. I believe you are correct.
Those Metal Cloak skids are awesome looking. Why did you go with those over others?
The agile package I am eyeing due to the smart use of materials and low friction poly. Same mindset is applied to my dirt bike skid plates and actually gliding across surfaces instead of pure steel gripping and getting gouged.
Got pics of how the plastic is taking the scrapes?
@Slov - I went with metalcloak because of the low profile, rust resistant properties and decent pricing.
Well I just got back home an hour ago after helping @BCDave with his Owl Skid Plates and Diff Covers today. This was the third one I have worked with and it still takes about 6 hours with two folks. We made life a bit easier by using a ratchet strap to help pull the rear skid plate forward to help get the bolts in.
Still not sure the feasibility of 6 hours and 2 people. I’m glad I cancelled my order in favor of Rivals, and will continue to watch the progress as others enter market. I would think the cost with UHMW, and install heavy time, this is not practical for a high percentage of IG owners who “off-road”.
I’m still convinced, in my situation I need these, but how much more protection will these truly provide, and ROI On Cost/time vs standard skids, to make it worthwhile?
I have the gen1 rival kit forward of the gas tank. But I didn't like the design of the rival gas tank skid plate so I opted for the agile skid plate for the gas tank. Really nicely built and much better install in my opinion. Has to make a tiny notch in the agile plate to accommodate the cross bar that rival shipped with it's plate but that was it.
Tried it today in Hollister hills and I'm super happy about it.
