Looks like we have choices in US for Diff Skid Plates
Over the decades I have run both Aluminum and Steel Skid plates.
From my experiences:
Steel weighs more than Aluminum
Aluminum tends to "stick" more on rocks as it is more malleable.
I "prefer" steel as it tends to "slide" more over rocks and it does not deform as much if you really land hard on it.
My 2 cents. :)
youre not getting 7075 t6 on anything sold. AO puts theirs as 5052 which is about 1/2 the tensile as a typical steel piece.
My 2 cents. :)
On the other hand, the Al has good rigidity for the wide expanse of the plates, and bonding a sheet of 3/16 4140 or 46100 in the wide impact area would be bombproof and give you bragging rights that your Ineos uses a custom engineered military spec layered armor system to protect critical systems and ensure combat survivability. …
I’m leaning towards the RIVAL versions. Anyone have some insights as to the install, outside of having taps for the screw holes? Need a lift to install?
a couple ramps if you dont mind laying on your back. I always used a motorcycle jack for skid plates, but there's aren't heavy steel so that's just an option.
Anyone have the RIVAL instructions? DO they do that Flag bolt thing like the Agile O version?
Also, on the color, as long as they are primed or painted some color, why not just use rattle can paint for color? It would allow easy touch up, and as long as they plates comes with some protective coating
Owl Vans now has aluminum with or without UHMW skid plates available with a replacement frame x-brace available. The diff skids are steel. They look rather good. I wish I knew they were making these.
Owl Vans now has aluminum with or without UHMW skid plates available with a replacement frame x-brace available. Looks like the diff skids are steel. They look rather good. I wish I knew they were making these.
That’s really interesting… I have the full set in a cart right now….
I've elected to return the Agile skid plates I had not yet installed and ordered a set of Owl's (Pro-Line in black). Agile's look good for the money at about $1100 less and with nice powder coat options, but I really like Owl's design. I may still get Agile's rear control arm skid plates since it doesn't look like the Owl kit has them, but I'm also not terribly worried about protecting those.
I pulled the trigger on the Owl ones too. We’ll see. My thought was get cheap ones and paint them until they fail and then replace. The OWL got me with the true ‘slider’ with the UHMW plastic, and the continuous run. Probably not smart buying it out the gate, but we’ll see.
Are you folks @DaneJa and @MileHigh doing your installs yourself or are you having the Denver Owl outfit in Longmont doing your installations? If they are installing it for you what is the cost? W/O having instructions I am hoping it is as easy as installing skids I have put on other off road vehicles in the past.
I don’t think they have the instructions yet so, they don’t have a cost for install. Part of it is going to depend on when they can actually get a time going to put it on. I don’t think they’ll be that difficult. All mechanical, no electronics.
Did you get any info as to when yours will ship?
I also don't think it can be that difficult. I have installed my share of skids and sliders so I don't believe there would be any issues.
Reactions: CRH
I only got an initial estimate that they would be done with production in two weeks. I assume I’m early in the queue to receive it, but they have not talked about shipping, or installation time. I inquired about the installation of a twin ARB brushless system, but they said there were issues with overheating and they only had the brushed older system. They quoted 450 for that install. I can’t imagine putting on skid plates would be more than that considering the electrical and other stuff that goes into the compressor install.
