Long term parking and battery discharge
Wir hatten einmal eine (fast) leere Batterie, obwohl die Anzeige nicht ausging. Der Motor sprang trotzdem an und die Batterie wurde über 30 Minuten mit über 100A geladen.
my loaner did that. mine? it will peak at 60 after staring and then goes to trickle charge. no such alternator enthusiasm.
My Grenadier has now been sitting for 21-days, and I’ll take it on a trip this weekend. I’ll post my battery SoC when I fire it up. BLE monitors fitted to both batteries, so I should get data from them as well.
Cracked gearbox doesn't sound good.. How did that happen? Thought it was near on indestructible
Result of the failed C clip in the front prop CV joint , which caused prop to fail a year ago, causing various damaged components and gearbox oil loss. . Small cracks where plastic oil pan screws go into the casting. Not picked up at the time of the repairs and has been weeping very slowly since. This was identified when it went in for other works.
JB Weld time!!
JB Weld time!!
Had I been somewhere remote and or out of warranty that’s what I would have done. Also out of warranty I’d have had the gearbox taken out and welded to repair it, once I could get to decent aluminium welder facility .
Case study: My Gren has been parked since 8-August. Doors were left open as I was fitting solar and stripping the interior. So in that time I probably only activated battery & head unit a few times.
EDIT: estimated 8-Aug SoC: 95%
7-Sept-2025
SoC: 77% as indicated on the head unit.
My battery monitors:
Victron satus page:
Coming off two days of rain so the sky is full cloudy. I’ll probably head out late afternoon and full sun is forecast for this week.
7-Sept-2025
Victron satus page:
What battery monitors are you using
@Logsplitter let me know if you find a UK supplier for these - i can see a bunch on ebay at £11 to £39, they 'look' the same'ish as the ones @TheDocAUS has in his blog but beyond that no idea.
There are several available from Amazon, also called BM2 in the title. The free App can only see one unit, but there is a $10 App that can track four units. I use that App to track (2) boat batteries and (2) Grenadier batteries.
What’s the difference between BM2 and BM6 as I’m seeing them listed.
edit ;-seems the newer ones monitor temperature and log last position the car was running /charging battery which may be useful if you forgot where you parked your car.
@TheDocAUS ?
I think the BM6 is the “Ancel” brand/type. I believe this unit can do multiple units on their free App.
BM2 is the “BLE” brand/type.
I don’t think it would make much if any difference between the two units.
@TheDocAUS ?
I believe you are correct.
There is a separate app for the BLE units that will do up to 4 units together.
BLE unit (it can be rebadged under other names). Has Lithium and Non-lithium models:
Ancel units (can also be rebadged under other names). Same model can monitor both AGM and Lithium batteries:
This seams as good as any place to post this. I was listening to a podcast (which is 10 million times better than ours) and they were talking about finding a battery drain in a Ferrari 456. They tried all the usual suspects and had no luck but then used a fantastic solution.
They parked the car overnight so that it was completely cooled in every system. The next morning, with minimal lighting in the shop, they used a thermal camera and "looked over" the car in search of any hot spots. They ultimately saw a heat signature in the interior - specifically the passenger sun visor where there was a short in the vanity mirror's light. Naturally Sir Jim made certain that specific scenario could play out in a Gren, but the thought of using a thermal cam to see what electrical items (hidden or otherwise) are generating heat is pretty crafty.
Our cooler season now (northern hemisphere) should make any ‘hot spots’ even easier to find. Let the hunt begin!
Latest posts
