Try turning your differential breathers. If they are hard to turn, they might be clogged. Rotating them can help free them up again. A clogged breather can cause pressure buildup, which may force hot oil out through seals or gaskets.
No I actually love the Grenadier, I think the design and concept is fantastic and the best available hence the reason I follow the progress, development and role out of the product and associated services.
It’s the atrocious build quality and after sales service that I dislike, I also find the excuses by those who love the vehicle so much they refuse to remove their rose coloured glasses a little amusing
Once Ineos get their act together and the vehicle is actually what was promised and a viable option for remote touring in Australia I will own at least 1 if not 2 before I am put in a box
Only difference the oil doesn't mix with the CV grease in the cavity it just leaks from the axle side of double cardan down the open housing out over the bottom king pin. Turn the wheel full lock and look into the swivel housing where the axle exits the main axle housing at the double cardan joint. The wheel bearings and king pins are greased so there would be less fluid if they leaked.Coming from the 70 and 80 series solid axle landcruiser world this looks like the fairly common appearance of a leaking outer axle seal. This allows diff oil to mix with the grease in the swivel hubs which thins out the grease and let's them leak on the lower king pin, inner part of wheel ect. Maybe I'm looking at the picture wrong and I dont have a solid understanding of the grenadier front axle but I would think it is similar in the basics.
Fair point. They seem to be available for £24, so not really worth the effort.I've made stuff like that with an impact socket and angle grinder
Wait til you see my 12th century forge welded torque wrenchFair point. They seem to be available for £24, so not really worth the effort.
That would explain a little bit.Wait til you see my 12th century forge welded torque wrench![]()
slightly older than 'the dawn of time' BobWait til you see my 12th century forge welded torque wrench![]()
There should have been a seal in between preventing lubricant transfer. At least that how LR (tried) to do it.Coming from the 70 and 80 series solid axle landcruiser world this looks like the fairly common appearance of a leaking outer axle seal. This allows diff oil to mix with the grease in the swivel hubs which thins out the grease and let's them leak on the lower king pin, inner part of wheel ect. Maybe I'm looking at the picture wrong and I dont have a solid understanding of the grenadier front axle but I would think it is similar in the basics.
Use a wrench to turn them. Turn them completely off and replace with open extended breathers.Try turning your differential breathers. If they are hard to turn, they might be clogged. Rotating them can help free them up again. A clogged breather can cause pressure buildup, which may force hot oil out through seals or gaskets.
Have you purchased your extended breather kit yet. I’ve placed an order for a generic ARB breather kit from Buzz Special Vehicles/Overland and separately placed an order for 10mm x 1 barbed hose tail connectors to suit the thread of the diff housing.quick update on this thread... there is no update...
bugger. do you have safaris?That brings me to the situation this morning. I get in the car for the school run to find this.
Looks like at least the windscreen passenger side top corner is leaking. The footwell carpet is wet. But where is the water coming from that results in it dripping off the a pillar grab handle (?)
Yup. I had what I thought was a good sniff about and it didn't feel like it was coming from the safari(?) but I could be wrong.bugger. do you have safaris?
Quite difficult to tell unless blatantly obvious, though definitely a weak point on some vehicles. Jean Mercier I think had some trouble with his early on. There's a drain hole etc that can become plugged. Various threads on it. Could also be a poorly bonded windscreen in that top left corner. Good luck and hope get sorted asap.Yup. I had what I thought was a good sniff about and it didn't feel like it was coming from the safari(?) but I could be wrong.
Assuming it's coming through the safari, it would be making it's way through the headlining all the way... What might that mean for all the electricals up there, and around the area ( not to mention rust trap and soggy insulation)
