Build Thread Kristina’s Build - Snuffleupagus
Awesome! Concerning the engine air filter - Correct.
I’m unable to convince myself that an oil based multi-layer foam filter is actually safe to filter input air for the compressor on this vehicle.
Oil entering the turbo intake seems like a very bad idea…
Certainly a valid concern! One thing to note, that side of the compressor inlet takes in blowby oil from the crankcase ventilation system. I just had my intake open last night and there's a light coating of oil inside the compressor outlet and charge pipe. This is normal for all engines and turbos. It's also why many install oil catch cans onto similar vehicles, which I may do down the line as I find a suitable kit (likely from a Toyota Supra application).
Read: this is oil vapor in the intake tract, not oil from the center cartridge, that's a huge problem!
Having an oiled filter is okay-ish, mostly a concern for the mass air flow MAF sensor if the filter is over-oiled after cleaning and re-oiling, which can be rectified by cleaning the sensor, but would rather not do.
The B57 diesel has one already; anyone check to see if the B58 is similarly equipped ex factory?
The thread on the Hengst "disc separator" is here. Hengst certainly make a petrol version, whether the INEOS has it is the question. AU diesel models have it.
Ah yep, the B58 does not get the Hengst separator. Looks quite cool in operation, would also require a software config and harness to run.
Where is this mounted for the B57 is this at the forward end of the engine bay by the (vehicle left) where the round fender cutout is in the nose under the bonnet behind the radiator? (quite a convoluted way to describe a location)
Speaking of engine air filters - My Volant Donaldson PowerCore G2 air filter ( Part #61509 ) and Volant pre-filter ( Part #51920 ) have arrived:
The additional mass is under ~700 lbs ( ~318 KG ) for this build - including supplies. I’d consider that pretty good. We’re using this for longer term ( multi-month / year ) international travel so it’s not really intended to be a rock or mall crawler. :-)
Finally had a chance to swing by a weight station earlier today - It looks like we’re ~6800 lbs ( ~3100 kgs ) fully loaded at this point.
@LazarusTheGrenny - Round 2 will start next week so stay tuned. This will cover snorkel and airbox, electronic brake controller, RTT mounted MaxTrax, and LRA ( Brown Davis ) Auxiliary tank installation.
Round 2 has begun. We’ve also added a set of clear ClimAir wind deflectors for the front and rear passenger and driver side windows.
Well things are happening… slowly:
Unfortunately US parcel inspection through LAX ( I assume Customs… bastards! ) decided to destroy one of the 3D printed fittings for the sealed airbox so we’re currently waiting for Rohan to ship out a replacement so we can finish our build. We’ve temporarily plumbed the GrenX snorkel into the OEM airbox for the moment.
BTW using the KOAN Stealth Folding MaxTrax mounts on a single Alu-Cab low profile load bar has worked wonderfully for the MaxTrax.
Additional heat shielding was also applied during the LRA Auxiliary tank install.
Pleased and proud to see a few Aussie brands and products in your build 👊
Crashpad
LRA (Brown Davis is a separate company)
Redarc
VAAST
GrenX
Plenty of other market brands in there also.
Nice work!
And now KAON, Maxtrax and GME. Plus JOOCLA who design and make the HOTTAP.
With REDARC Kristina has the hat trick with the ALPHA 50 amp DC to DC charger, Tow Pro and Lithium battery.
How do you like the fit up in the GrenX airbox after my suggestion for this filter & pre-filter sock?
I find it to be a little bit of a non-optimal stack up, but should work no problem.
I don’t think proper sealing is an issue but it’s definitely a PITA to install.
I’ve played with this a bit before we kick off the remainder of the snorkel install - The fit within the sealed airbox is very tight. It may be worthwhile to trim the circumference of the filter body slightly to make this a bit easier…
REDARC Tow-Pro EBC setup. Mounted under the rear ( bench ) seat with Agile Offroad’s bracket:
The EBC adjustment knob has been mounted at the base of the e-brake:
Exhaust configuration for the LRA Auxiliary fuel tank ( from R differential ):
On another entirely unrelated note - The CV joints ( F and R ) seem to look pretty good at the moment:
Hopefully they stay that way…
