Issue with Wolbox mirror
Major_B
Quartermaster Owner
6:41 PM
Belgium
I have a weird issue with my Tri Pro: it has been a few weeks that it switches automatically in reverse mode (see attached photo). From there I can’t switch back to normal modes, I can’t even go to the settings panel. I did not wired it to the reverse light, the corresponding wire is tucked and isolated close to the rear camera.
Have you ever had this issue? Maybe @WolfBox can you private message me to discuss?
Thanks
Mine seems to randomly switch off and alternate between front and rear facing cameras (but never randomly switches to the third low down forward facing camera). It usually seems to go back to the rear facing angle that I want with a few prods on the touch screen. I have been too lazy to read the instruction book which might have an answer as to how to stop it occurring but it's not a big issue as the wing mirrors provide a more than adequate back up.
Make sure all of your leads are well plugged in - I got the same symptoms with a loose plug.
Indeed thanks @WolfBox I forgot about this connector and found it soaked in a gutter of my rack.
Blow dried both ends and made a watertight seal but still some unwanted changes. I’ll let it dry for a few days and contact service if needed.
