Interior Rattle at Low RPM
Jonathan
Forum Supporter
11:45 PM
Schwäbisch Hall
Hi,
I have an annoying noise in the cabin when the engine is idling. It feels like it's slowly getting worse. At idle, something is vibrating or rattling. When I give it a bit of gas and the revs go up, the noise eventually disappears.
To me, it doesn't sound like it's anything critical, but I can't be sure. Mainly, it's just annoying because it sounds cheap and it's about four times louder inside the car compared to when the noise isn't there.
Has anyone got an idea what it could be, or maybe experienced something similar in their Grenadier?
Thanks and best regards,
Jon
Hi,
Jon
We call them kids in Australia. :)
One possibility is loose heat shields under the car being vibrated. My rattles sounded internal when they were in fact from under the car.
My heat shields would rattle at low speeds. Once they were adjusted problem solved.
:giggle: ah yes, but this I do not have only on low rpm ;)
It does seem like it’s louder inside the car than outside.
But thanks for the tip about the heat shields – I’ll definitely check that!
You just need to go through a process of elimination until you find it.
Have to tried to find the source? What if you pop it into neutral? Does it go away immediately ?
It’s not a well known issue.. just triage it on your own.. it’s loud enough to make it feasible
Yes, I’ll try to find it. I just thought I’d ask — it could have been that someone already knows exactly what it is. The noise happens in N, D, and R, so it doesn’t matter which gear. I think something is vibrating at a certain frequency… when I was underneath it today, I saw a few cables that could possibly be causing it… I also think I’ll figure out what it is :)
Thank you for your responses.
I’m experiencing a similar issue. It seems to be getting a little worse, so I’m going to look into it. It’s only at idle, and not in park. A little throttle and it silences out. Heat shields and cables underneath are my first thought.
Mine turned out to be roof rack. I added some rubber strips in between the panels and frame. Thread lock on the bolts. Seems to be rock solid and quiet now. It was really annoying me. Hope you find yours!
