Installed NEW Fox 2.0 ATS Steering Stabilizer June 2025
I’ve had both the first gen (non adjustable) agile offroad and recently added the ATS from agile. I would not waste your money on gen one, it does the trick, but it had vibration on the steering wheel over every bump and was not as stable as the ATS on the highway. I have mine now set at 18 clicks and it’s perfect for me and tracks well on the highway at the same time we installed this @Dokatd and I adjusted my steering stops. We simply ran the nut all the way to the base of the screw and then reinstalled. I can now do a U-turn on a six lane divided thoroughfare without hitting the curb! I can also do a three point turn now instead of a four-point turn like a battleship.
How will that affect the UJ. joint in the swivel housing. Will it put extra strain on it especially off-road. I’m no mechanic but I’ve just been looking at the online portal and it seems the more you turn the wheel, the more angle there is on that front axle UJ joint
Same design as a Unimog and some tractor designs. All steer vastly sharper than the Ineos even after the stop adjustment. The adjustment Tex is talking about is minimal to what some have done. I have had mine set the same way for thousands of miles. I personally know a couple people that went further with the adjustment and have tens of thousands of miles. In terms of off-road, you always need to be cautious when steering sharply and applying lots of torque. I personally believe Ineos was over conservative with this concern and compromised on road maneuverability. Heck, they were so conservative they compromised off-road ability.
What you are saying may have some merit, but. After a chat to the head of operations at IA about certain tolerances they have built into the Grenadier all may not be what you think. To say I was disappointed with his response is an understatement.
Can you enlighten me more 🤔
I have the non-adjustable Fox stabilizer. I think it works great and makes the steering feel "normal". It's only a couple hundred bucks and takes 10 mins to install, so worth a try if you're unsure. I personally wouldn't bother with the adjustable one unless you have some niche use case.
I don't really notice the loose steering anymore, but I don't know if that's because of the stabilizer or if I just got used to it.
I also have this one and it works great…big improvement .
Well, elaborate. I suspect I already know, but let's hear it.
