Installed NEW Fox 2.0 ATS Steering Stabilizer June 2025
mrchanute
8:51 PM
United States
All: I've read a bunch of posts, watched a lot of videos, etc...and just installed my new Fox Shocks Race Series 2.0 ATS Steering Stabilizer as purchased from Owl Vans. No more messing with extra parts, bolt on clamps, etc. It took me roughly 30 minutes to remove the factory Bilstein stabilizer and bolt on the new Fox stabilizer. HOWEVER - you need to have the following tools available. Metric allen wrench, flat blade screwdriver, Metric size 18 and size 21 sockets AND a torque wrench for the sockets. (Plus something to pry ever so gently on the factor welded bracket to spread it approximately 1/16th to 1/8th of an inch to accommodate the stabilizer). It was that simple. Unbolt the old one which consists of two bolts with welded nuts so no need to try and get a wrench on the top nuts. Set the old stabilizer on the ground, loosely tighten the right side of the new stabilizer using the factory bolt, hold up the left side to the welded bracket and spread it a bit if necessary (turn the stabilizers adjuster screw fully counterclockwise to make it easier to line up the holes by hand), then use the factory bolt to secure the left side. Tighten the left to approx 105 ft pounds, and the right to approx 70 ft pounds. And finally - adjust the adjuster screw with the flatblade to attain the performance you desire.
Contemplating getting a Fox ATS 2.0 stabilizer but reading various post about them and everyone’s comments with regard to how it feels after install I can’t really decide. The weight of the stock steering and slow return to center after turning a corner I don’t find all that bothersome but the constant adjustments at speed is a bit tiresome especially on longer journeys and hoping the ATS can help with that somewhat?
I know Agile mentions setting the ATS prior to shipment to what they think will be best but how does that setting compare to the stock unit? I assume it would be somewhat softer but can the ATS be adjusted back to the stock level of stiffness if needed or is the top end of the adjustment still softer than stock?
I have the non-adjustable Fox stabilizer. I think it works great and makes the steering feel "normal". It's only a couple hundred bucks and takes 10 mins to install, so worth a try if you're unsure. I personally wouldn't bother with the adjustable one unless you have some niche use case.
I don't really notice the loose steering anymore, but I don't know if that's because of the stabilizer or if I just got used to it.
The ATS will 100% solve the highway issues. The reason it does is simply because of its lower rate than the stock. That said, you can turn it up to almost the same as the stock if you really want to. You can also turn it down debatably too low. It really allows you to dial in the feel.
Just curious what setting are you finding works best? I’m about 8 clicks from the lowest point but didn’t experiment with various settings to see what works better.
Good to know it will help solve the highway issues. I’m not looking for F1 levels of steering precision as anyone who thinks they can achieve so with the Grenadier’s setup is going to be in for a bit of a disappointment. Rather, I want to find a sweet spot where the overall steering resistance is still relatively high but just soft enough to help with some of the highway waywardness. The ATS looks to be the only option offering some level of adjustment.
Any advice on how to store the OEM unit for use as a spare? Store it extended, mid-travel or compressed?
Not explicitly aimed at you, but what is it with all these posts, mostly from US owners, about requiring constant adjustments? Is the US version built differently from the rest of the world, so it has this characteristic?
If I let go of the wheel, it tracks straight (bar camber or road damage). There is no need for constant corrections. Indeed, when you look at some of the videos on YouTube and you see US drivers constantly moving the wheel less than a half-inch back and forth, it seems strange. Some look like they are in a 1950s movie driving a static studio car. If I move the wheel back and forth a half inch, it isn't enough to make any difference. So, those micro adjustments are not actually doing anything other than telling your brain that you think you are doing something. I can just rest a hand on the wheel and it just doesn't need correcting.
My daughter did this overcorrecting when she first drove the Grenadier. She also did it in the 2015 Defender Puma. But on both, she dialled it out once she realised that they both tracked straight, and the corrections she was making were not making the slightest difference. I got her to release her hands from the wheel, and she realised that it would carry on straight. I also told her not to grip the wheel but to relax on it and guide the car. She soon stopped the oversteering and the unnecessary corrections as every time she realised she was overcorrecting, she released the wheel and relaxed.
I wonder if it is the wallow in the car, linked to how high you sit that you get an upside down pendulum effect where your head is swaying from the body roll and your brain thinks you have to correct it. If you can dial that out, then it's fine, but people are different and not all can find that equilibrium.
Definitely doesn't affect all US units. Mine tracks straight with the OEM stabalizer. The return to center is still Grenadier slow but is objectively better than it was when new…it actually spins a few rotations now without help😂😂, albeit still too slowly without driver input to complete a turn.
Has to do with speed and road conditions I suspect. The truck does "ok" around 60mph and below if you ignore the lack of self centering.
I have found that either possibly the later models or the models with road tires seem to not have as much issue.
This is not a movie car issue, the truck will depart the roadway if you don't make corrections. It's purely the stiffness or stiction of the steering combined with the slop in the steering box that cause the minor changes to be necessary. You basically have to turn the steering wheel back and forth through the steering boxes backlash to make the corrections. Again, not as much 60mph and below and on good condition roads.
Installing a lighter stabilizer reduces and almost eliminates one of the two major factors (Stiction) and makes the truck much more livable. The added benefit is almost proper self centering around corners at low speed. It's a win win all around.
Again, I have said this many times, this is almost certainly a US problem because of the higher road speeds and long distances we drive in the country of freedom.
Certainly no F1 precision, but much better. I think a lot of people here confuse the complaints of some as not being used to heavy steering. This is certainly not the case. My Gwagon has vastly heavier steering than my Gren. The heavy feeling comes more from power steering pressure than anything. You will find the steering a bit lighter for sure, but not much depending on your prefered setting.
I started at the setting suggested by Owl or Agile who ever it was. I have now gone 2-3 clicks harder and feel it's pretty good.
Just store your stock one vertically with the shaft side up and collapsed. It's really not critical at all, but that would be the preferred method just because the chance of it leaking is lower. Ultimately you will realize it's just garbage and in the way. Same with the factory shocks 😂
Nothing is different steering setup wise between US & UK markets (besides the obvious LH/RH) that I’m aware of. And I don’t think US owners are auditioning to be in the next Hitchcock type film featuring a rear projection scene while driving a fake car. :)
This is more of a road condition issue coupled with a very stiff or high rate steering stabilizer, and typical for the design, central dead spot in the steering box. High stiction in the system means you have to turn the wheel through or past the dead spot to have any meaningful change of direction. Countries with more curved road systems where you are typically moving back and forth through the dead spot and against the stiction as you drive along so any waywardness would be less noticeable I would think.
It’s not uncommon in the US to encounter asphalt, concrete, course road grade, high cambered, crumbling and rutted road surfaces over the course of a short distance on a single highway system (Yeah, our road infrastructure sucks as well especially in the permanently under construction Mountain West). Also, it’s not uncommon in the West to travel 25 to 50 miles at a time on basically an arrow straight road with no curves and poor surfaces. So a slow steering ratio coupled with a rather stiff stabilizer often means the steering responds to an imperfection on the road and takes a set and without a correction you can easily start to move out of your lane especially above 60 MPH.
I own plenty of old Land Rovers with the common Adwest steering box design (which basically perfected the notion of vague steering feel) and the Grenadier’s is very similar in feel overall but I’d go as far to say even my restored Range Rover Classic is a bit less fiddly on the highway requiring much fewer corrections at the wheel. Then gain, the weight of the components and geometry is obviously different between the vehicles.
I’m not complaining about the steering in the Grenadier per-se, as for the most part it works for what the vehicle was designed for but I’ll take a small improvement if a legitimate one exists especially since switching out the stabilizer takes only a few minutes. I will freely admit the steering has improved slightly as things continue to break-in and become a bit smoother. I’m not looking to change the entire character of the steering system and actually prefer the overall heft but a bit less steering correction would be most welcome on longer drives.
Welcome to the dark side C-Mack. I believe you will find it much more comfortable over here.
Setting 12 of 24 gets you 90% of what might feel "normal". I like 90% of the way there and unwinding the last 10% to be "intentional". I am sure setting it at 24 would be near the factory setting. it is good to have choices.
Interesting, I don't have to contend with wondering steering with our high speed country roads, one of our medium sized states in Australia, the Northern Territory approximately twice the size of Texas has a speed limit that varies from 130kmh ( 81mph ) to unlimited, and a population of 231,000 in the last senses. Probably a bit of positive caster helps with that " not wondering ".
We drive in the real country of freedom.
I will now duck for cover.
We have a 23.5 fieldmaster and looking for some guidance ref the steering.
SHMBO has wrist issues and struggles on longer drives with the adjustments and force required on the wheel, motorway driving towing a caravan. The previous vehicle was a 4.3 landcruiser, this was never an issue.
Would the fox adjustable damper benefit her adjusted suitably? Will it also be able to be dialed back to near the origonal factory set when off the tarmac.
She loves the granny but is frustrated at not being able to do as much driving as previously with the cruiser.
Ta,
G
Ta,
G
Yes
Dumb/uninformed question...!
Will this stabilizer also fit the RHD models?
Hi David,
Thanks for reaching out! The Fox ATS steering stabilizer will not work on a right-hand drive Grenadier. Our standard smooth body steering stabilizer will work.
Thanks
Agile Offroad Team
