INEOS using less Torx bolts/screws?
TheDocAUS
9:19 PM
Eromanga
Just FYI.
My car (VIN 7719) does not have Torx bolts on the door sills (drivers and passenger doors checked so far), but hex head bolts. I know earlier cars had Torx bolts.
INEOS are still using Torx elsewhere, like the bonnet opening lever and the second bolt/screw under the lever and in the battery box.
Cost cutting ...
Supply problems ...
Who knows? 🤷‍♂️
There's a couple of issues with Torx that might be the change reason.
Firstly, since they are really good at high torque fastening, they are easy to over-torque. Shouldn't be an issue on a production line with torque limiting tools, however easy for an operative to set the torque wrongly and strip out a thread on something that doesn't need it.
You can use the next size down on Torx and it still will turn the head, with a risk of stripping of course. You can't do this with hex head.
Just FYI.
From memory mine has hex bolts. It’s a sub 2500 VIN
