INEOS Grenadier Quick Ref Guide Specifications - Fluids, Alignment Spec, Disc Brake specs
angstorms
Forum Donor
12:49 PM
Durango, CO, USA
Hey found this Ineos document why searching online for update fluid spec. it has Fluids, Alignment Spec, Disc Brake specs
INEOS Grenadier Quick Ref Guide Specifications pdf
That's handy, thanks for posting it.
So I wanted to see what I could get here in Durango, Colorado off the shelf or with 1 day order do web order and pickup at the store .
  • Stearing: Pentosin Hydraulic Fluid 1 Liter - CHF11S
  • Cooling: Zerex 1 Gallon Green Concentrate Antifreeze - 904685
  • Brake Fluid: Pentosin 1 Liter DOT 4 Brake Fluid - BF-DOT4LV-1L
  • Engine Oil: Castrol Edge Full Synthetic Motor Oil 5W-30 1 Quart - EDGE5-30A3/B4
  • Transfer Case Oil: 75W-90 - There are few brands
  • Gear Oil: SAE 80W-90 GL-5 - There are few brands
if I wanted ZF Fluid for the transmission I would do an order from Amazon or see if O'reily could special order.
  • Transmission Oil:
    • ZF Transmission Fluid Lifeguard Fluid 8
    • Pentosin Lifeguard 8 ATF 3+ Auto Trans Fluid
Very handy, thanks!
Regarding alignment, what's actually adjustable on the stock suspension? I'm presuming toe and nothing else.
