Not around these here partsTwo questions:
1. Isn’t there any regulation or required test for fuel tanks? What happens when the Chinese tank leaks or breaks in an accident?
1. This question applies equally to the auxiliary tanks from Long Range Automotive, Brown Davis, FK and Skyline and is why these style tanks are often labeled as to be for off road use only.Two questions:
2. Could you find anything about the hight of it? I can imagine that it takes some of the ground clearance under it (I actually did not check how much I have under the original one)
Will you be installing both the main and aux tanks from Skyline?Sounds like the tank is ready. Payment through PayPal.![]()
I'm very interested in your experience.That is the plan.
Please consider a full write up on the install and your impressions of the tanks while in use.Arrived today. Very well packed and looks good based on a quick once over.
And what was the full price to you including tariffs?Arrived today. Very well packed and looks good based on a quick once over.
How much lower does that hang down? It looks a bit lower than I first thought? look a bit lower than the rock sliders.Little different driving experience. 150 miles since fill up and still on full. Talked with Skyline and they said that is normal. The top of the tank is larger leading to this. Normally I would be filling up later this weekend, feels weird.
Play around with the range, according to Fibonacci
View: https://www.facebook.com/share/v/1AxtuXHbty/
Not at all. It's not even worthy of the Dull Men's Club Facebook groupWould I be a total nerd if I admitted I found that interesting ?
