Increased Fuel Tank
Using just the replacement 37.7 gal main tank from Skyline would provide a great deal of additional range. I am seriously considering it. If it turns out to be rubbish the OEM tank could be put back in. I suspect getting the Euro version resonator center section for the exhaust will cost as much as the Skyline main tank :LOL:.
Have any of you guys done the beermat maths on what this does to your weight, payload and front and rear spring rates?
It would be nice if these companies would publish the net weight difference after modification not just the weight of their own products.
I'm doing similar currently. I had the LRA 68 litre diesel aux tank fitted this week but have yet to fill both tanks to see the effect on my ride height. I do have airbags for towing but full tanks plus towball weight might be too much for airbags alone so there could be a rear spring change required due to the net weight gain. TBD.
The original rear muffler weighs 10kg. I stood on the scales with it today. That's the diesel muffler. I haven't checked if the petrol Grenadier has the same rear muffler part number but the weight will be similar.
Fully loaded the extra fuel and added tank increase load by ~210lbs pretty close to centered on the back seat. I didn’t go any further than that.
So roughly 13% loss of payload on a clean skin wagon. Not horrible but that's going on top of whatever other weight has already been added during a build. It's worth keeping in mind if your vehicle is already a bit tubby.
My conservative beermat calcs have the BD tank etc at approx 20kg plus 68L x.spec grav of 0.85 for diesel = say 58 kg minus 10kg for the muffler... so 68kg total.
The "moment" of a full aux. tank in terms of its chassis position, exerted on the rear axle is approx 75kg.(I think😉)
My LRA kit shipping weight is 36kg so I'll use that figure.
They squeezed 66 litres into the tank during leak testing. 66 x 0.85SG = 57kg with a full filler pipe.
Deduct the rear muffler @ 10kg.
Tank net weight:
(36+57)-10 = +83kg net gain full.
36-10 = +26kg net gain empty.
The LRA tank centre is 0.4m behind the axle. The wheelbase is 2.92m.
Wheelbase leverage (the moment):
Full. 83kg x (0.4m/2.92m) = 11.37kg.
Empty. 26kg x (0.4m/2.92m) = 3.56kg.
Rear axle load (tank + leverage):
83 + 11.37 = +94.37kg gain when full.
36 + 3.56 = +39.57kg gain when empty.
That's close to your beermat based on a lighter tank @DenisM :geek:
the hangover GIF
I'm getting the LRA tank and putting a heavy winch, tray, and bar on the front -- a lot of weight that hopefully somewhat balances out. The Skyline tanks look like a more complete and CG-balanced solution, but are also more complex. I like that the LRA tank doesn't touch the OEM tank and allows the use of currently available skid plates. My tank skid has taken a beating and it looks like the Skyline tanks sit about the same level as the OEM.
The math is good.
The way I look at it, if you need the fuel you are going to need to carry it somewhere and down low in a purpose built hold is better than 8x20lt jerrycans on the roof.
I look forward to hydrogen power. Then we can put a heap of jerry cans on the roof and float to our destination 🤪
Two questions:
1. Isn’t there any regulation or required test for fuel tanks? What happens when the Chinese tank leaks or breaks in an accident?
2. Could you find anything about the hight of it? I can imagine that it takes some of the ground clearance under it (I actually did not check how much I have under the original one)
